okay thank you, I been here many times to get my textures.. Just was not clear about the Transparency image window thing...
Now, if the image for that plant does not come with a "separate" transparency image... then I'll be in trouble... ;) I guess I have to go looking for it right? I'll look to see what the other "working " images are doing.... and go from there...
Much thanks...
You should find the transparency maps in the same folder as the textures so take a look. The illustration I used was one of the DAZ Environment elements that are used in the Woodland Realms Playsets.
And if it doesn't, you can always do an alpha channel (which is just a black and white image).
Hugz from Phoenix, USA
Victoria
![file_358041.jpg](https://live.cdn.renderosity.com/forum/threads/2670895/file_358041.jpg)
I just downloaded an environmental WoodlandRealm put it into Poser 6 and Studio... In Studio it looks great but when imported into Bryce 6, One 2D plane is not working right... see pic. It looks Black..I tries to change the vegetation image on it to see if that was it and no... It seems to be the plane it self... Does it happen to anyone else on these evironmental packs... How could a 2d plane go wrong..:( I could erase it...
Thank you
Tom
