Tue, Nov 12, 6:18 PM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Getting a material to conform to shape of object
mikebres ( ) posted Tue, 14 November 2006 at 11:55 PM · edited Tue, 12 November 2024 at 6:14 PM
I've created an object in Hexagon 2.  I've mapped the UV so it conforms to the curve of my object.  I have imported the object into Vue 6 and now I want to apply a material to the object that follows the UV mapping.  How do I do that?
Thanks
Mike
dburdick ( ) posted Wed, 15 November 2006 at 12:08 AM
Set the material in Vue to object standard mapping which will apply the material to how your UV Map looks.
mikebres ( ) posted Wed, 15 November 2006 at 10:00 AM
Okay.  After reading your post I tried what you suggested.  It didn't work.  So I got to thinking that maybe the UV data didn't get exported from Hexagon.  I went back to Hex and checked the export and found that 3DS didn't mention anything about UV coordinates.  So I exported in Wavefront OBJ format and kept the UV data. However, when I tried to import this object into Vue 6, it crashed.  Just to make sure I tried it a couple more times.  Each time Vue 6 crashed.  So I tried it in Vue 5, it imported without any problems. However (again :-), the material didn't follow the UV mapping.  See image.  I added a plane with the same material to show how it's supposed to look.
Any ideas?
Thanks
