Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Sep 17 7:30 pm)
This was addressed here back before release of Poser Pro-Pack, but after installing PPP I find the following procedure doesn't work any more......................................... "Adding objects to a library without transparency showing on thumbnail? by nerd on 7/22/00"......... "1. For PC set color depth to any thing but 32 Bit. 2. Render the object 3. Display> Paste rendered image onto background. 4. Move camera so only the background is visible. 5. Now save your figure to the library. The rendered image will now show in the library"...................................................................................... I am on a PC with 24 bit color depth. Poser 4.03 with Pro-Pack. Any suggestions appreciated..... Buck
