Tue, Feb 11, 9:29 AM CST
Subject: How do you use Bryce models in Poser?
Mogwa ( ) posted Fri, 01 December 2006 at 12:52 PM · edited Mon, 10 February 2025 at 11:13 AM
While I've run across lots of information on how to use Poser models in Bryce, I can't find any instructions on reversing the procedure. Pardon me if this is a stupid question, but are there any methods for converting Bryce obp's and material textures into Poser 5 or 6?
nruddock ( ) posted Fri, 01 December 2006 at 1:14 PM
The latest version (6.0) is the first one that allows you to convert booleans to mesh and thus export them (fiddly but possible).
Previous versions have allowed export of previously imported meshes (also rocks and terains/lattices).
There isstill no (easy or otherwise) way to get materials out of Bryce, so you'll have to redo the materials in Poser.
rickymaveety ( ) posted Fri, 01 December 2006 at 1:25 PM
You can't convert an obp file, but you can take your boolean model and turn it into an obj file (there is now a "C" at the bottom of the object menu that I would assume stands for "Convert to Mesh").
Once you have converted the object to a mesh, you can export it, and then import it into Poser.
I looks like Bryce also creates UV maps for the saved obj, although I'm going to have to look into that a little further.  I was playing with creating some boolean models in Bryce and I suddenly found all sorts of UV maps had been created ... but, when and how, I have no idea.
Could be worse, could be raining.
Thom1965 ( ) posted Fri, 01 December 2006 at 6:41 PM
If you looke at the product description for this:
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=51980
the merchant gives a nice description (I haven't tried it yet) of how to get both
the model and the texture out of Bryce for use in other programs.
Hope that helps :)
Mogwa ( ) posted Fri, 01 December 2006 at 8:00 PM
Thanks to everyone for the help!
