Tue, Feb 11, 11:47 AM CST
Subject: Lightting problems
moldie ( ) posted Mon, 30 April 2001 at 9:44 PM ยท edited Tue, 11 February 2025 at 11:45 AM
This is the victoria model with bump mapping, texture, and normal lighting effects. Why the hell does it look so screwed? Look at the right side of her mouth and the back of her head. What am I doing wrong?
Ghostofmacbeth ( ) posted Mon, 30 April 2001 at 10:07 PM
Think it looks like the same thing that happened to picnic .. the tif file for the bump map needs to be reloaded so it comes in as a bump map. Think it makes a difference normally but not in the Pro Pack .... do that and you should be golden
moldie ( ) posted Mon, 30 April 2001 at 10:16 PM
Whoa... Do what? I'm not using any TIF files that I know of. And how would I reload it?
Ghostofmacbeth ( ) posted Mon, 30 April 2001 at 11:30 PM
Thought this was the new Vicki map .. if so there is a good chance it comes in as a tif for the bump .. what you can do it turn the bump to none and then load them again. you might need to quit, that will purge it from memory and then load .. it will then convert it to a bump. Som of the smudging also looks to be a shadow map on the lights ..increase the thing from the default of map size 256 to something like 700 or more ...that should nuke most smudging
moldie ( ) posted Tue, 01 May 2001 at 3:42 AM
I fixed it, but not like that.
Ghostofmacbeth ( ) posted Tue, 01 May 2001 at 10:24 AM
Okay ... I also realized there is one Pro Pack version and one P4 version .. the pro pack will do that .. the P4 shouldn't
