Tue, Jan 7, 12:20 AM CST
Subject: Wardrobe Wizard Question
Anniebel ( ) posted Sat, 09 December 2006 at 3:37 AM · edited Sun, 05 January 2025 at 8:36 AM
Ok I bought WW a little while ago, & have been a bit slow to utilize it.
WIth the release of V4 I thought I'd better get familiar with it.
Now I have a few questions - I tried searching the forums, but am getting too many hits.
Anyway, the first outfit I tried was Hongyu's Jersey dress for V3 to fit Aiko 3. It worked ok & it fits, but there are no morphs in the resulting figure, like the original - Is this normal, are the morphs generally lost? If so, what do you do when you pose the figure, some of the fit is lost then, how do you deal with poke through? Also with no morphs, how do you pose the clothing to make it drape more natually - I am thinking or longer items etc?
Thanks
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
Anniebel ( ) posted Sat, 09 December 2006 at 4:03 AM · edited Sat, 09 December 2006 at 4:04 AM
This is what I mean, normally I would fix the poke through with the morphs that come with the clothing, but after using WW there is none.
Helen Keller
Little_Dragon ( ) posted Sat, 09 December 2006 at 4:07 AM
If you retained the original grouping, you should be able to transfer the morphs to the modified item by means of Morph Manager or some other utility.
arcady ( ) posted Sat, 09 December 2006 at 4:14 AM
Need to convert to using the advanced mode. Convert to with unregrouped un... whatever the other option you can 'un' was called... :)
PhilC has a tutorial on this, and there is a help webpage located in the same folders that have the python script for it. Load up that webpage and keep it open when you use WW until you've exhausted and memorized all the little tricks it has to show you. PhilC has the best tutorials and help information of anybody in the 3D world I've come across so far.
Truth has no value without backing by unfounded belief.
Renderosity Gallery
Anniebel ( ) posted Sat, 09 December 2006 at 4:22 AM
I had the tut open as I converted & followed his instructions, there was no mention of this though.
Helen Keller
PhilC ( ) posted Sat, 09 December 2006 at 5:42 AM
Attached Link: http://www.philc.net/WW_tutorial1.htm
The tutorial you need is at this link.
Also looking at your first image try posing the figure's buttocks rather than the thigh. This isn't a Wardrobe Wizard thing, you'll get this with any skirt using this rigging configuration.
If things are still not clear please post further. I and many others are always happy to respond.
Anniebel ( ) posted Sat, 09 December 2006 at 5:14 PM
Thanks Phil, I will have a try with this.
Helen Keller
