Tue, Feb 25, 5:36 PM CST
Forum Moderators: RedPhantom
Subject: obj prop
asmith ( ) posted Tue, 01 May 2001 at 7:38 AM ยท edited Tue, 25 February 2025 at 5:13 PM
Hi guys, been a member forever, but this is my first post in years. I am trying to create a prop of a sculpture. I am using a figure to do this, when I save it in obj format and bring it back in to poser when I click on render materials it still shows the seperate body parts for texturing, how can I get it to come back as one object so I can apply one texture, not just the same texture for the seperate body parts? The way it is now the texture is not uniform through the whole object..............Thanks
Wizzard ( ) posted Tue, 01 May 2001 at 7:55 AM
export it as a 3ds... that way tis all of a piece..... then re-import is into POser.. and material away.. at least it usually works for me 8 ) Cheers
asmith ( ) posted Tue, 01 May 2001 at 8:47 AM
First off thanks for your quick responce, I have tried this and it does spreads the texture over the entire prop, which is good. However with the object in the window when I click on render materials then materials it still shows all the seperate body parts, although not a big deal, it shows the characters name and as a prop I would like it not to be that specific. Is it possible to eliminate that? ................Thanks again
Wizzard ( ) posted Tue, 01 May 2001 at 10:30 AM
easy enough.... open the heirarchy rename the prop... hrmmmm.. I"m trying to remember if I pulled the 3ds into another programme and reassigned the mats... I may have... but it should come in all of a colour and applying the mat to all should give full coverage... Cheers
asmith ( ) posted Tue, 01 May 2001 at 1:27 PM
Thanks Wizzard, that seem to do the trick...Asmith
Wizzard ( ) posted Thu, 03 May 2001 at 12:16 AM
you're welcome 8 )
