Never had that problem either - when you zoom out, do a test render. It could just be a display issue and not really happening physically to the light.
If it's happening physically to the light and it shows in your test render... I haven't the foggiest f---ing notion (wide-eyed, shrugs). If that's the case, email e-on.
-Lew ;-)
I think Bruno has something. You can switch on/off something in the preferences. That lights and cameras are displayed always the same size. Maybe this causes this optical effect.
Funny to read something about physically happening in this case, shows how real we feel this all here. All virtual in a computer Lew! :-))))
hey Buddy .. i think its a optical illusion .. to check it, move the Top camera to the side and try it again with the main Cam .. when you think its on the floor ..check it with the top cam...
Hope this helps ...
Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
@Wabe - yeah, I know it's not real ("Do you think that's 'air' you're breathing?") - it's just the only way I could think to describe it. ;-)
If the light actually drops in its coordinates, the test render will show that (shadows falling in a new direction, etc.). If the lighting doesn't change in the render, it's an optical illusion of the display - or happening with the display of objects.
-Lew ;-)
I know you were joking ;-) I was just reinforcing the joke with the quote - smiling when I typed it.
The quote was from "The Matrix" during the first training fight in the dojo - between Morpheus and Neo - he was trying to get Neo to understand that everything there is an illusion - even the notion that it's not really air he's breathing at that point.
There's some research statistic claiming that over 40 percent of any typed messages are misunderstood, or the intention misread - a HUGE part of our communications is "reading the other person" through body language, verbal inflections, facial expression, etc. Totally lost reading type.
Don't worry - I knew you were joking ;-)
I know this'll be a really easy answer but I'm having a shit day ok [:-))]
Why, when I zoom out does my main light drop onto the floor?
I know it'll be really simple 'cos when I zoom back in it goes back up!!!
Thanx if you tell this dummy the answer!!
Injustice will be avenged.
Cofiwch Dryweryn.
