Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 4:26 pm)
... Just re-read my post above and realized it made no sense. Must have gotten one thread crossed with another while thinking about other things.
Anyway, still - thank you. I guess it will be a Naked Vicky, maybe hanging out with a naked Sydney...
Which sounds like something on late night cable TV... :oops:
Truth has no value without backing by unfounded belief.
Renderosity
Gallery
Hey thanks man :))) Only it's causing P6 and P7 to hang ... Any idea what to do to fix this ?
Oh okay no I havent the hi-res textures installed Thanks I'll go and buy them then tere should be no problem :)
After my problems with Poser 6 hanging, I decided to try this in Poser 5 (loaded V4 and applied the morph) and found it was looking for the Standar Res (not Hi-Res) textures. (I purchased the Victoria Pro bundle and it comes with the Hi-Res textures. )
So.... Poser 6 hangs because it couldn't find the standard res whereas Poser 5 gave up and provided a dialog box for where to find V4StTorsoS.jpg.
I then purchased and installed the standard res textures from DAZ and it now works.
Thanks much to WTB for a fantastic job and others who helped resolve this.
I hope this helps others with the Poser 6 hangs.
Russ
Cool, I'm so glad everyone likes it. When people attempt this, someone invariably says "Hasn't the creator ever seen a vagina before???" So one worries, ya know.
the answer, of course, is not nearly enough. However, I think that this is the best we can hope for given the number of polygons in the area. For sure though, this was an intentional "gimmie" from DAZ, because the way they are laid out demands the morphs be made.
-WTB
Quote - Strixowl, it appears you're correct, and I obviously must have forgotten to download it and install it. With all of the downloads for the Pro bundle its easy to do I guess)
Nevertheless, a slightly expensive lesson for me on that.
Daz offers a 30 day refund policy for situations like yours were you have double ordered.
Contact them and give them order numbers, and ask to have one of the two textures refunded.
Renderosity
Gallery
WTB, would you possibly make what you do have available so we have something to work with even if you are not realy satisfied with it yourself? I would apreciate any morph that built up the structure and helped get the sculpting going. Since I can't figure out any modeling software I do everything in Poser using your Universal Magic Mags and it helps if the structures are already raised out a bit as shown in your WIP. I thought it looked pretty good. Either way... thanks for "showing yours" :)
Thank you.
Now I have to do that 'Naked Sydney in a temple with an Aston Martin' image... :)
Renderosity Gallery
