Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 4:06 am)
Attached Link: http://www.poseworks.com/serendipity/index.php?/categories/3-Python
poseworks did a simple script to do this (see attached link).IIRC, bagginsbill posted something similar at RDNA.
Attached Link: ShaderWorks
ShaderWorks by semidieu will let you rename nodes as well as a few of other things. It's a standalone program, but it does require you to have Microsoft Framework 2.0 installed.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Therer are a lot of things that can be done on the Materials Room in Poser 5 and Poser 6, but there's one awkwardness I've found. Some shader tricks need the same numerical value in several different node settings. There's a couple of tricks to get around this: Just use an Add math_function, for instance. But this, and a lot of other things, are easier to work with, six months later, if you could just change the label for a node. That is, the name in the top-bar. There are ways to do this by hand-editing the material file, and content creators have done this. But does Poser 7 have some simple way of changing the labels, so that instead of "math_function_27" I can just have something called "Stripe Width"?
