Sat, Nov 23, 8:02 PM CST
Subject: P7 Library question
ronwindham ( ) posted Sat, 16 December 2006 at 5:36 PM · edited Sat, 23 November 2024 at 7:27 PM
Got 7 installed runtimes moved into it.....Now in the library thing I click the little triangle for the pull down listing all I get is add new catagory and build folder menu nothing else no txt listing all icons.. am i missing something someplace.......
Victoria_Lee ( ) posted Sat, 16 December 2006 at 6:23 PM
Are you using external runtimes?  If so, you need to add them to the P7 library.  When you click on the triangle that's to add a new collection category.  I'm using that right now to build collections of the characters, hair, props and lights I use most often so that I can access them quickly.  They don't have to be in the same runtime which is a great feature since my external runtimes are broken up by a lot of different things.
Hugz from Phoenix, USA
Victoria
ronwindham ( ) posted Sat, 16 December 2006 at 6:35 PM
no external runtimes......the library shows all the folders....figures, props and so on....and only shows folders in the library thing. in 6 when you clicked on the triangle you got  a text listing you could scroll thru. now with 7 only get folder views.....have to scroll thru all folders instead of the pull down thing.
Dizzi ( ) posted Sat, 16 December 2006 at 6:50 PM
Poser 7 doesn't seem to like big runtimes... I'd suggest to report that to EF so they are going to fix it...
ronwindham ( ) posted Sat, 16 December 2006 at 6:56 PM
yeah did that too..............just thot someone here may know whats up
