Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
Clean your DVD drive - had the same problem until I ran a cleaning disk. Also, you are using a DVD drive, right? You have to have that for the app to install. The content cd is just a cd but the app disk is a DVD.
Hugz from Phoenix, USA
Victoria
Thanks for suggestion, I cleaned the drive and checked to see what it was. It is a Phillips CDRW/DVD SCB5265. I wonder if it only reads a certain format of DVDs. Since the drive indicator in the folder for Poser 7 shows it as a CD it may be that that is the problem. The drive does read some DVDs but I really don't use it that much for DVDs. I did send an email to E-frontier support. I wonder how they will fix this. Maybe I will have to download it. Buying a new drive is not an option. Oh well, more waiting while everyone else wows and woos.
Another suggestion - update your drivers. The Phillips site should have updated drivers for the drive. I'm using a Toshiba but will be adding a Sony to the array this week. I updated my drivers when I cleaned the disk.
Victoria
It might also require a firmware update of the drive - so keep your eyes open for something like this for your DVD drive while at Phillips' site - my old Sony DRU-500A had one of these to allow 4x DVD writes.
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
It seems the drive I have in my laptop supports the wrong kind-of DVD format. So I went out and bought myself a new external DVD/CD drive (HP 940e) that supposedly supports every darn DVD format. And...it worked, read the Poser CD no problem. So, I am finally seeing how Poser 7 measures up...so far so good.
Thanks to all for the suggestions.
Just an FYI--got my hard copy today in the mail and went to install, which it did, but wouldn't open. Every time I clicked to open, it would for a fraction of a second and shut down. Went through uninstall and install a couple of times to no avail. Called Customer support a couple of times--no answer. I took a look at the installed file system and I couldn't find the P7 folder--strange, where did they install too? There was no separate P7 folder! So, I had to manually created one to install too and voila problem solved. So, reading all these threads for the last week and the problems that have popped up, I thought it might help someone else who might run into this same problem. I surmise the default install might have gone to the P6 folder and conflicted with that version. Anyway, now it's time to play with my new virtual people.
Happy Rendering!
