Tue, Nov 26, 3:19 AM CST
Subject: Veins for m3
darth_poserus ( ) posted Mon, 18 December 2006 at 6:32 AM · edited Fri, 22 November 2024 at 4:09 PM
Can someone tell us how you go about creating the look of veins beneath the skin on m3?
"I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge." Albert Einstein
Free the freebies!
adamthwaites ( ) posted Mon, 18 December 2006 at 7:37 AM
Hi darth,
The way I paint veins is to get a texture then duplicate it as a new layer in Photoshop and reduce the opacity, then make another new layer that I paint veins on and basically sandwhich that in between the original texture and the copy of the original at lower opacity. It kind of looks like the veins are under a layer of skin then.
Hope that helps a bit.
Cheers
Ad
www.most-digital-creations.com
jonthecelt ( ) posted Mon, 18 December 2006 at 7:49 AM
Best way would be to create a displacement map. Whether there are any decent ones out there in freebies or market place is beyond me, but if all else fails, you'd probably have to learn how to make your own.
That's assuming you mean the bumps in the skin that show veins, of course. If you're talking about the bluish coloration you getwhen the veins are near the surface, then there may be a procedural method for adding them to your existing colour texture map. Failing that, it's adding them in in photoshop or other image eidting software.
Sorry can't be of much more help than this,
jonthecelt
wrpspeed ( ) posted Mon, 18 December 2006 at 9:12 AM
trekie girl has a bump map for veins in the freebie section. i add it in in the material room and
use a setting of .02
darth_poserus ( ) posted Tue, 19 December 2006 at 4:36 PM
Thanks everyone. I appreciate the help.
Free the freebies!
