Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Attached Link: http://www.keindesign.de/stefan/poser/scripts/p7/turn%20off%20texture%20filtering.py
> Quote - Can anyone tell me in P7- How do I turn off texture filtering ? > I can't seem to find out where it is located now. > cheerio lululeeThere is now a setting on each Image_Map node.
stewer wrote a script to turn it off for all nodes (save attached link).
However, because of P7's new texture paging code, having texture filtering turned on won't cause memory problems like it did in P6.
SAMS3D:
You can run it manually by clicking File>Run Python Script and selecting the script, or you can drop the script into the "RuntimePythonposerScriptsScriptsMenuUtility" folder then start/restart poser and it will be in the Scripts>Utility menu. Just click it and it turns off texture filtering on ALL image map nodes. There's no visible confirmation or anything, but it DOES work.
I dropped the file in the WacrosUserDefined folder, so when I go into the Material Room all I have to do is click the "User Defined" button, and it pops up as the only option.
________________________________________________________________
If you're joking that's just cruel, but if you're being sarcastic, that's even worse.
I really recommend leaving texture filtering turned on in P7. If you're worried about memory, stop worrying: filtered textures in P7 will use less memory than unfiltered textures in P6 If you're worried about speed, switch to fast filtering. Especially when using lots of large textures, rendering without filtering will be slower than with. If you're worried about quality, look again: filter quality has improved over P6.
I've done actual comparisons of skin textures with texture filtering on and off, and the filtering off was sharper, even if P7.
Transmapped hair looks better with it on though.
cheerio lululee
