Sat, Nov 30, 8:00 PM CST
Subject: Poser 7 wont load an object
iloco ( ) posted Wed, 20 December 2006 at 3:30 PM · edited Sat, 30 November 2024 at 7:57 PM
Has anyone loaded the P7-Roadster Maiko that is in the Poser 7 library in Figures Poser 7.
When I try to load it hangs up on me and I have to use the task manager to shut down Poser 7 to be able to use again. :(
I am curious if anyone else has this problem.
ïÏøçö
Victoria_Lee ( ) posted Wed, 20 December 2006 at 3:49 PM
I haven't tried it yet but I've seen in the forums that this is happening to a lot of people.
Hugz from Phoenix, USA
Victoria
iloco ( ) posted Wed, 20 December 2006 at 3:52 PM
Thank you. I am glad to know its not only me having the problem. :)
ïÏøçö
Victoria_Lee ( ) posted Wed, 20 December 2006 at 4:20 PM
I think this is why I've not tried loading the model ... lol.  Too many people having problems with it and reporting it to e-Frontier.
Victoria
nruddock ( ) posted Wed, 20 December 2006 at 5:51 PM
The car is extremely polygon heavy (~500,000) so it will take time to load.
iloco ( ) posted Wed, 20 December 2006 at 6:26 PM
I know but my poser 7 quit responding when loading it. :(
ïÏøçö
nruddock ( ) posted Wed, 20 December 2006 at 7:16 PM
Quote - I know but my poser 7 quit responding when loading it. :(
How long did you wait ?
On my machine it takes 2 mins 20 secs to load.
iloco ( ) posted Wed, 20 December 2006 at 7:48 PM · edited Wed, 20 December 2006 at 7:56 PM
I t took me longer than that.  I dint keep the time but will try once more and let it run a while. :(
UPDATE:  It took 6 1/2 minutes and finally did load.   Thanks for everyones help.
 I need to upgrade my computer big time next year if I continue to use the 3d software that is coming out now. :)
ïÏøçö
nerd ( ) posted Wed, 20 December 2006 at 7:57 PM
Forum Moderator
I takes quite a while to load. It's just a gazzilion polygons. Low memory systems will take a reeeeely long time to load it.
R_Hatch ( ) posted Thu, 21 December 2006 at 12:18 AM
If you're planning to use it in a lot of scenes, and want it to load faster, export it as OBJ. I imported the base OBJ and it took a lot less time than loading the figure. Keep in mind that you will lose the posability, however.
nruddock ( ) posted Thu, 21 December 2006 at 4:39 AM
Quote - If you're planning to use it in a lot of scenes, and want it to load faster, export it as OBJ. I imported the base OBJ and it took a lot less time than loading the figure. Keep in mind that you will lose the posability, however.
... and the materials setup.
R_Hatch ( ) posted Thu, 28 December 2006 at 3:01 AM
You could use CR2Builder to transfer those over, after saving as a prop :)
Netherworks ( ) posted Thu, 28 December 2006 at 4:36 AM
Is the roadster a static object or a figure?
I'm scared to look after reading all over about it :D
I have the idea to drop it in the modeler and do a polygon reduction on it ;)
nruddock ( ) posted Thu, 28 December 2006 at 5:50 AM
Quote - Is the roadster a static object or a figure?
It's a figure.
A lot the the polygon weight is in small but highly curved areas like the rear lights.
thefixer ( ) posted Thu, 28 December 2006 at 9:30 AM
Nerd: Waht do you call "low memory system"? I have 2 Gig and it won't load on mine, are you saying that 2Gig is too small for P7???
Injustice will be avenged.
Cofiwch Dryweryn.
nerd ( ) posted Thu, 28 December 2006 at 12:03 PM
Forum Moderator
It loads on my Laptop which is a 1 GB system, but it takes about 5 minutes.
factor ( ) posted Thu, 28 December 2006 at 12:25 PM
Hi ya all....
**"Good old" Fixer brought it to THE POINT
If 2 Gigs are really to small for ANY Program... Then there is something WRONG with the SOFTWARE... NOT with our Systems!!!!!
After ready all this Bugreports (i agree with most... some i couldnt find (yet).
**MY answer is:
**I have two Systems running on 2 Harddrives, and... after getting nuts with the Delete-KEY... (the Render-Progressbar also is NOT correct in my Poser 7.... its fully filled when the render STARTS!!!)... i switched back to "Good old Poser 6".
That was the badest Christmasgift i`ve EVER GOT! Question is: When does the first Servicepack arrive??????
Greetz, Factor.... and everybody a good switch to 2007.
Hope that this next Year don`t asks for more Memory,too! Germany is allready an error!
thefixer ( ) posted Thu, 28 December 2006 at 12:39 PM
Hey Factor, not so much of the OLD!!!  [ROFL]
Cofiwch Dryweryn.
factor ( ) posted Thu, 28 December 2006 at 1:08 PM · edited Thu, 28 December 2006 at 1:13 PM
Hey Dude....   ;-)
*I wrote the "Good old" in QUOTES!!!
See ya... hm... (unfortunately not possible!) ... **READ YA!
Ray
P.S.: "Germany... an error"** I mean that politically.... the county itself is wonderful! Im BORN here... but dont agree with the political System. Its the same sh** as in all of the world: The RICH get richer, the POOR get poorer!*
Morgano ( ) posted Thu, 28 December 2006 at 4:01 PM
I think 2Gb remains the most that Poser can even theoretically handle, because it's 32-bit code.
