Click Build Folder Menu BUT only after you have saved. A lot of us experience crashes when doing that but it seems P7 crashes only if you're accessing a huge runtime since the tech team has been unable to reproduce it.
I'd even suggest not using the Poser libraries at all and using Yarp's P3DO Explorer along with Tromnek's PRPC script to open Poser content, be able to read the entire file name and browse at your leisure :)
Glad I could help Oliver :)
Linda, yes it works perfectly in P7. But another glitch in P7 is that you can only run one script at once so if you want to run something else you'll have to turn off the PRPC script and run it again.
There hasn't been any formal word from EF if it was intended for P7 to run only one script or if it's something that will eventually get fixed.
