Fri, Nov 29, 10:59 PM CST
Subject: Poser 7 - Dropdown Library Menu disapeard...
oliveramberg ( ) posted Fri, 29 December 2006 at 6:22 AM · edited Fri, 29 November 2024 at 10:58 PM
Hi Today I started Poser 7 and wanted to browse through my characters. I clicked for the dropdown-menu that shows all the characters but all I can see is "Build folder menu..." and "Add a new category". Yesterday everything worked smooth...strange. Any ideas how I get the menu back?
Kalypso ( ) posted Fri, 29 December 2006 at 9:27 AM
Site Admin
Click Build Folder Menu BUT only after you have saved.  A lot of us experience crashes when doing that but it seems P7 crashes only if you're accessing a huge runtime since the tech team has been unable to reproduce it.
I'd even suggest not using the Poser libraries at all and using Yarp's P3DO Explorer along with Tromnek's PRPC script to open Poser content, be able to read the entire file name and browse at your leisure :)
http://www.senosoft.com/index.php
http://prpc.sourceforge.net/
oliveramberg ( ) posted Fri, 29 December 2006 at 9:36 AM
Thank you very much Kalypso!
LindaB ( ) posted Fri, 29 December 2006 at 9:56 AM
Will the script work with Poser 7?
Kalypso ( ) posted Fri, 29 December 2006 at 11:31 AM
Site Admin
Glad I could help Oliver :)
Linda, yes it works perfectly in P7.  But another glitch in P7 is that you can only run one script at once so if you want to run something else you'll have to turn off the PRPC script and run it again.
There hasn't been any formal word from EF if it was intended for P7 to run only one script or if it's something that will eventually get fixed.
LindaB ( ) posted Fri, 29 December 2006 at 12:12 PM
Thanks Kalpso, I'll give it a try.
