Fri, Jan 3, 8:17 PM CST
Subject: P7 and Shaid Material Scripts
Philip9000 ( ) posted Fri, 29 December 2006 at 10:21 AM · edited Sat, 10 August 2024 at 5:45 AM
I have been trying out the Shaid material scripts. They seem to work okay for me in P6.  However, after loading to the P7, I get the following error message:
Traceback (most recent call last):
  File "D:Program Filese frontierPoser 7RuntimePythonPoserScriptsWacrosShaidShaidGroup1.py", line 3, in ?
    import shaidGrp
ImportError: Bad magic number in D:Program Filese frontierPoser 7RuntimePythonPoserScriptsWacrosShaidshaidGrp.pyc
I dont know enough about Python to figure this out on my own yet.  My Poser .exe's are loaded on D: drive.  With P6 under Program FilesCurious Labs and P7 under Program Filese Frontier... if it matters.  I did load the Shaid .py scripts separately into each respective Runtime.
Thoughts?
thanks
Philip9000 ( ) posted Fri, 29 December 2006 at 10:22 AM
By the way, I did check the scripts to see if there was a specific path or Poser version referenced.  To the best of my ability, I don't see that there are either.
Victoria_Lee ( ) posted Fri, 29 December 2006 at 10:33 AM
The P7 python engine uses a different compiler, from what I understand, so compiled scripts need to be recompiled for P7.  Some of my scripts work fine in P7 and some don't.  PhilC (http://www.philc.net) can explain it better since he had to recompile the Wardrobe Wizard script for P7.
Hugz from Phoenix, USA
Victoria
Lucifer_The_Dark ( ) posted Fri, 29 December 2006 at 10:35 AM · edited Fri, 29 December 2006 at 10:36 AM
I think you'll find the problem is Poser, or rather the version of Python that each different version uses, afaik Poser6 uses v2.2 & Poser7 uses v2.4, any scripts compiled with the older version have to be recompiled with the newer to work with it. A quick pm to the creator of the script will hopefully solve it if they've bought Poser7, if not you're stuck until they do.
Beaten again!!!!!!! :D :D
Windows 7 64Bit
Poser Pro 2010 SR1
Philip9000 ( ) posted Thu, 03 May 2007 at 8:28 PM
Thanks... I will see if I can learn something about recompiling scripts... anyone have any thoughts?  Can a user do this, or does the author need to do it?
LostinSpaceman ( ) posted Thu, 03 May 2007 at 9:43 PM
The author will have to do it unless he distributed the uncompiled code for that pyc file which I seriuosly doubt or it wouldn't have had to be compiled in the first place.
