Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 05 11:51 pm)
The P7 python engine uses a different compiler, from what I understand, so compiled scripts need to be recompiled for P7. Some of my scripts work fine in P7 and some don't. PhilC (http://www.philc.net) can explain it better since he had to recompile the Wardrobe Wizard script for P7.
Hugz from Phoenix, USA
Victoria
I think you'll find the problem is Poser, or rather the version of Python that each different version uses, afaik Poser6 uses v2.2 & Poser7 uses v2.4, any scripts compiled with the older version have to be recompiled with the newer to work with it. A quick pm to the creator of the script will hopefully solve it if they've bought Poser7, if not you're stuck until they do.
Beaten again!!!!!!! :D :D
Windows 7 64Bit
Poser Pro 2010 SR1
I have been trying out the Shaid material scripts. They seem to work okay for me in P6. However, after loading to the P7, I get the following error message:
Traceback (most recent call last):
File "D:Program Filese frontierPoser 7RuntimePythonPoserScriptsWacrosShaidShaidGroup1.py", line 3, in ?
import shaidGrp
ImportError: Bad magic number in D:Program Filese frontierPoser 7RuntimePythonPoserScriptsWacrosShaidshaidGrp.pyc
I dont know enough about Python to figure this out on my own yet. My Poser .exe's are loaded on D: drive. With P6 under Program FilesCurious Labs and P7 under Program Filese Frontier... if it matters. I did load the Shaid .py scripts separately into each respective Runtime.
Thoughts?
thanks
