Fri, Nov 15, 4:32 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 4:06 am)
Subject: Poser 7 crash, won't load!!
Mhawke ( ) posted Mon, 01 January 2007 at 11:15 PM · edited Fri, 15 November 2024 at 2:55 AM
Apologies if this situation has been covered before.
Installed Poser 7 about 10 days ago.
All was running fine, worked up several images,  till it apparently garbaged a .pz3 file.
Trying to open the file resulted in a windows error message that poser had caused a Windows fault and would close. After that the program would not even load without causing a crash.
Since then I have uninstalled and re-unstalled Poser7 4 times.
Even searched the windows registry and removed all reference to poser7 that I could find.
Tried installing in different directories and on different hard disk (same computer though).
Each time now it crashes on start-up, the program won't even load.
I still have Poser6 installed and it runs fine.
I also have Carrara, Hex, DAZStudio, Photoshop CS and several others and no problems.
Running diagnostics on my systems turns up no errors.
I have made no changes to my system or installed any additional programs since installing and running Poser7 10 days ago, all other programs run without problems.
I doubt the the installer files are corrupt as the program was originally installed from the same files and was running great prior to the (aparently) corrupted file issue.
I'm a IT guy and this one has me totally stumped.
Any advice appreciated.
nruddock ( ) posted Tue, 02 January 2007 at 12:11 AM
Did you remove the user preference files ?
These are no longer in the Poser directory tree, they've been moved to ":Documents and SettingsApplication DataPoser 7" and so wouldn't be removed by an uninstall.
Mhawke ( ) posted Tue, 02 January 2007 at 6:57 AM
DAMN!!!!!!!!!!!!!!!!
That was it. Thanks a million.
Apparently there was a corrupted ,pz3 file set to autoload, deleting that file and the .pmd, now the program starts properly.
Didn't realize (feel like a dummy now!) that settings were stored in that directory.
Thanks again.
nruddock ( ) posted Tue, 02 January 2007 at 10:38 AM
ReadMes are wonderful things 😉
