Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 10:35 am)
Well, you can click on the value listed next to the dial and type in a number directly, but to my knowledge that's about it as far as keyboard manipulation of posers parameter dials.
The only other "keyboard" responses of note here are the up and down arrow keys, they will allow you to cycle through the chosen parameter for your parameter dial, IE, if you have the Body of a figure selected and hit your down arrow key, it will go to the next body part listed in the heirarchy (such as hip, abdomen, etc..) and you can keep cycling through till you get to the desired selection on the parameter dial screen.
Works for lights and cameras as well, BTW.
If your using Windows, It can be done (sort of). Open Controle Panel, select Accessability Options, select the Mouse tab, tick Use MouseKeys, make sure the Number Lock is on. You can now controle the paramiter dials with the neumeric keypad arrow keys, BUT you have to hold down the left moues button whilst you do it, and the cursor must be over the dial.
Is there any way to manipulate the dials via the keyboard (arrow keys or something)?
Thanks!
