Thu, Nov 28, 11:37 PM CST
Subject: Anyway of using the keyboard to adjust the dials?
Nebula ( ) posted Tue, 02 January 2007 at 11:18 AM · edited Thu, 28 November 2024 at 9:45 PM
Is there any way to manipulate the dials via the keyboard (arrow keys or something)?
Thanks!
trobbins2 ( ) posted Tue, 02 January 2007 at 11:25 AM
Well, you can click on the value listed next to the dial and type in a number directly, but to my knowledge that's about it as far as keyboard manipulation of posers parameter dials.
The only other "keyboard" responses of note here are the up and down arrow keys, they will allow you to cycle through the chosen parameter for your parameter dial, IE, if you have the Body of a figure selected and hit your down arrow key, it will go to the next body part listed in the heirarchy (such as hip, abdomen, etc..) and you can keep cycling through till you get to the desired selection on the parameter dial screen.
Works for lights and cameras as well, BTW.
Nebula ( ) posted Tue, 02 January 2007 at 11:31 AM
Yeah, I do that already.  Just a pain sometimes cause it seems the mouse is not sensitive enough.  But I do appricate the response tho!
Thanks!
nruddock ( ) posted Tue, 02 January 2007 at 1:39 PM
If you double click on a dial, you get a Settings dialog and altering the value for "Sensitivity" will change how the dial responds to the mouse.
IIRC, versions of Poser earlier than P7 (or perhaps P6 SR3) may not save / respond to saved changes.
jerr3d ( ) posted Tue, 02 January 2007 at 6:33 PM
and you can try, click on dial, then click on graph button and in that window drag the marker up or down to adjust the settng
lesbentley ( ) posted Wed, 03 January 2007 at 8:31 PM
If your using Windows, It can be done (sort of). Open Controle Panel, select Accessability Options, select the Mouse tab, tick Use MouseKeys, make sure the Number Lock is on. You can now controle the paramiter dials with the neumeric keypad arrow keys, BUT you have to hold down the left moues button whilst you do it, and the cursor must be over the dial.
