Tue, Feb 4, 3:25 AM CST
Subject: Real world modeling - A turotial...of sorts
Claymor ( ) posted Tue, 02 January 2007 at 10:59 PM · edited Tue, 04 February 2025 at 3:10 AM
I think I have finally gone completely mad. I am sure it is probably just the cabin fever. We've had two snow storms of multiple feet each over the last couiple weeks here in Colorado. People stranded, stores running out of food....real wrath of God kinda stuff. With all the folks getting stuck we thought we should be prepared to help. So if you find yourself with a lot of extra snow laying around.... ...this modeling tutorial is for you.
Step one: Proper Attire
Baby, it's cold outside...boots, jacket, gloves and most importantly hat, all required
Claymor ( ) posted Tue, 02 January 2007 at 11:02 PM
Step two: Primatives
Everybody knows a good Bryce render begins with Primatives.
In this case, to satisfy the most rigorous of purists, we use the blue bucket in the previous image to create, by hand, individual primatives that we'll use to contruct our model. In all we'll need about 100 of these before we're finished.
Claymor ( ) posted Tue, 02 January 2007 at 11:05 PM
Step Three:  Foundation
A good snowy texture is essential on your ground plane for this scene.
Create a circle laying out the first row of primative neo-cubes.
Be sure to close in that last gap or you'll be in for trouble later on.
Notice that this initial layer of primatives is set on the snow plane and NOT on the ground plane beneath. That allows you to boolean out a bit of a door later on.
Claymor ( ) posted Tue, 02 January 2007 at 11:09 PM
Step four: First Pass Render
By then end of your first session you should have completed at least stacking four rows or primative neo-cubes and boolean cut a door somewhere low on the side away from the wind.
You'll find that it is important to boolean cut the top of each row so that they begin to angle in towards the center of your circle. The angle should be increased with each succesive row.
Believe me..I wish I had figured that out earlier.
Obviously this process took sometime and so I decided to change the background lighting from day to night. This isn't necessary however. You can work it out however you'd like.
Death_at_Midnight ( ) posted Tue, 02 January 2007 at 11:13 PM
Hrm, interesting camera view. :-)
Claymor ( ) posted Tue, 02 January 2007 at 11:16 PM
Step five: Lather, Rinse, Repeat
If you look closely enough you'll see less snow in the background along the fence. Again this isn't a requirement. It just so happened that an indoor soccer tournament interrupted the project so we we unable to continue for a day or two.
Once we started back up though we were able to add another row of neo-cubes.
Then came the hard part. Because we had only a single form to use for the creation of primatives the stacking process was delayed until more primatives could be formed. This need not be a problem for you if: 1. You use more than one form or 2. you do that AND have more people helping you or 3. You create all 100 primatives before you start stacking.
Anyway...that slowed the render time down quite a bit....
Claymor ( ) posted Tue, 02 January 2007 at 11:19 PM
Step six: Finishing touches
I told you the render time was slowed quite a bit...day becomes night again while you wait...BUT...
Once the additional primatives are created you can continue stacking.
At this point you need to consider a LOT of boolean cutting and a fairly steep interior angle on your rows of primatives.
I wish I had known that earlier....
The kid with his head sticking out the top is about 5'2" and standing on his tip toes...I added him in to this render for a sense of scale.
Claymor ( ) posted Tue, 02 January 2007 at 11:23 PM
Step seven: The morning after
IF you knew earlier how MUCH to angle each succesive row the top of your structure would come out more like a dome rather than this sort of wigwamish/hogan shape.
Still...even with that bit of trouble the top of the strucutre is enclosed and it can be boolean carved on the outside to round off the edges.
I chose not to because even at 6'2" I was stretched as tall as I could get to get the last few primatives to the top.
Claymor ( ) posted Tue, 02 January 2007 at 11:28 PM
In all an interesting project though one that resulted in sore hamstrings and a sore back.
The resultant structure is big enough that my 11 year old can stand fully inside in the middle of it and the floor is big enough to sit all five of us comfortably.
If it makes it through the temps in the 50's the next two days and lasts until the snow comes back Friday we may even try to sleep in it this weekend.
The upside is we've told the kids that as long as this thing is standing, if they're disobedient, the punishment will be 20 minutes in the igloo in naught but their undies.
Here's wishing each of you a happy 2007 and a year that is better than your previous one. No matter how good (or bad) 2006 was.
erosiaart ( ) posted Wed, 03 January 2007 at 1:37 AM
:lol:, :thumbupboth: , :woot: ,
the most perfect real world render ever! cool!!
Flak ( ) posted Wed, 03 January 2007 at 2:22 AM
A true brycer  - creating his own primitives lol. Excellent stuff.
Digital WasteLanD
draculaz ( ) posted Wed, 03 January 2007 at 2:53 AM
bah, this could have been done so much more easily with box modelling...
m
RodsArt ( ) posted Wed, 03 January 2007 at 4:02 AM
Happy 2007 wishes to you too brother. Cabin fever comes to mind, although we on the east coast have been spared up to this point.
Great project!
___
Ockham's razor- It's that simple
TheBryster ( ) posted Wed, 03 January 2007 at 4:20 AM · edited Wed, 03 January 2007 at 4:20 AM
ROTFLMAO !!!!
Brilliantly Done !
rickymaveety ( ) posted Wed, 03 January 2007 at 8:27 AM
Really beautiful, hogan shaped or not.  I won't even deduct points for the missing inverted U tunnel that is typically leading up to the door.  It's too pretty to deduct points.
Could be worse, could be raining.
Incognitas ( ) posted Wed, 03 January 2007 at 8:40 AM
Ah basking in temperatures of 11%C here in the South of England.Snow?what's snow?What's Winter?
In fact it does seem so far that we have passed straight to Spring...the primroses are in full bloom down in the town's Memorial Gardens on the seafront.
Death_at_Midnight ( ) posted Wed, 03 January 2007 at 11:42 AM
I like the ambient light! ;-)  That's some realistic snow mat's you're using. Like the bump height.
It doesn't snow down here in Texas except rarely. Well... at least the first two Christmas's I was here it snowed.
Claymor ( ) posted Wed, 03 January 2007 at 11:46 AM
As far as I can tell the "inverted U" doorway is really all about protection from the weather. You get that short hallway that helps keep wind and blowing snow out. In my case it would just mean needing to crawl further on my belly.
No thanks.
sackrat ( ) posted Wed, 03 January 2007 at 2:57 PM
Nicely done ! Got way too much time on your hands, huh ? Jeez,...........I just looked outside at the thermometer,........it's reading 64 degrees, bright sun, not a cloud to be seen,..............ta-ta  for now.
"Any club that would have me as a member is probably not worth joining" -Groucho Marx
rickymaveety ( ) posted Wed, 03 January 2007 at 3:42 PM
Well, I see your point ... although the whole idea of the igloo is protection from the weather, and it looks from here like you had a whole bunch of very nasty weather.
TheBryster ( ) posted Wed, 03 January 2007 at 4:52 PM
Hangon! If the whole point of an igloo is to protect you from the bad weather wouldn't it make sense to build the igloo BEFORE the weather gets bad?  😕
Dann-O ( ) posted Wed, 03 January 2007 at 5:36 PM
Well while that would make some sense bryster the bad weather supplies the needed materials to make your igloo. Without it you can only make the emperors new igloo which any child will tell you is. .........  Miss doing stuff like that.
The wit of a misplaced ex-patriot.
I cheated on my metaphysics exam by looking into the soul of the person next to me.
skiwillgee ( ) posted Wed, 03 January 2007 at 10:24 PM
PERFECT RENDERING.   Adds a whole new meaning to book titled "Real World Bryce"
@Drac.  okay heretic.  Let's see you create a handle on some sort of snow plane and stretch and pull an igloo from your hat!  Primatives my friend are the answer.
Elfwine ( ) posted Thu, 04 January 2007 at 3:05 AM
now me... I just extrude a demi-human shape by falling over backwards and flailing my arms and legs!
 Don't sweat the petty things, and don't pet the sweaty things!  ; )
Ang25 ( ) posted Fri, 05 January 2007 at 1:43 PM
I LOVE IT !   And I'm so frigging glad that we are having a warm winter (so far) here in the northeast. I will add Colorado to my growing list of places to never move to. Along with Antartica, Alaska and Buffalo NY. oh almost forgot - All of Canada too.
TheBryster ( ) posted Fri, 05 January 2007 at 2:43 PM
Hangon, Ang! Canada's just a spit from where you live..................:huh:
Claymor ( ) posted Fri, 05 January 2007 at 3:47 PM
But a WORLD away culturally.....
Incarnadine ( ) posted Fri, 05 January 2007 at 9:54 PM
Yup!
I was out in just a leather jacket today. this is freaky. Should be about -10C at this time of year.
Claymor ( ) posted Fri, 05 January 2007 at 10:25 PM
Yeah well...we got our third storm in three weeks today. Yet another day of school closures...which is really VERY rare here. It has to be BAD for schools to close.
I AM READY TO MOVE BACK TO CALIFORNIA!!!!
