Sun, Jan 12, 12:10 AM CST
Subject: White line in shadow: artifact ........help!
isaacnewton ( ) posted Sat, 13 January 2007 at 7:27 AM ยท edited Tue, 24 December 2024 at 8:34 PM
...excuses.... the system has shrunk the image :( ... double click on it to see a larger version
Hi Folks,
I wonder if anyone can help out with explaining some Poser wierdness, and hopefully how to avoid it.
I have noticed that when I use Ambient Occlusion (AO) to get better shadows at skin-to-skin contacts, I sometimes get white lines appearing where the shadow should be darkest (like a dynamic range overload causing an inversion... or something like that).
In panel A of the picture is the kind of AO shadow I expect, but even here if you look closely (see panel B for magnification) you can see the beginings of the effect.
Panel C (a picture of gymnastic contortions :) ) shows that in some shadows the effect is there (red) and in others (green) it is not.
In some images this artifact is very strong, with a really white line running down the middle of a shadow.
I am using AO on the shaders (AO on lights switched off), using Occlusion Master (by face_off) and Unimesh Realism Kit (also by face_off).
Obviously this artifact is due to the lighting but I'm not sure what aspect of the lighting is causing it or how I can avoid it.
I use an IBL light and spotlights (usually a light set by R3DF).
If anyone can ... er... shed more light on this problem I would be grateful.
Thanks,
Isaac
jonthecelt ( ) posted Sat, 13 January 2007 at 7:47 AM
bookmark
isaacnewton ( ) posted Sun, 14 January 2007 at 4:23 AM
Come on you Poser Gurus... someone must have found a solution to this one...
I think jonthecelt wants to know too :)
nghayward ( ) posted Sun, 14 January 2007 at 5:25 AM
I was able to replicate the problem in a scene that originally was ok by raising the Ray Bias in the material's AO node. Try running Occlusion Master again and lowering the ray bias value
isaacnewton ( ) posted Sun, 14 January 2007 at 9:14 AM
Thanks nghaywood.... that appears to do the trick. Reducing Ray Bias from 0.4 to 0.1 seems to work, but I guess it will depend on many factors like how close I'm zoomed in, light intensity etc...
Still, now I know what to do when this particular Ugly raises it's head :)
Thanks,
Isaac
