Tue, Jan 21, 3:47 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Subject: Poser 7 & Text editors
Anniebel ( ) posted Mon, 15 January 2007 at 1:50 PM · edited Tue, 21 January 2025 at 3:34 PM
Well, I just opened a P7 material file in Edit Pad & it is all gobbledegook, so I looked at a couple of other files - pose etc. Just the same.
So how do you edit a file now?
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
Lucifer_The_Dark ( ) posted Mon, 15 January 2007 at 2:00 PM · edited Mon, 15 January 2007 at 2:01 PM
was it a compressed file? did it end with .mtz? if it was you can't read them with just any old text editor without uncompressing them first, there's a script in Poser for doing just that. Be careful though as it can uncompress everything leaving you badly short of HD space.
ps any of the files that has an extention that ends with z are compressed.
Windows 7 64Bit
Poser Pro 2010 SR1
Tyger_purr ( ) posted Mon, 15 January 2007 at 2:08 PM
what file type are you looking at?
mc6 or mcz?
if it has a "z" in the extension then it is a compressed file and to edit it you just run the uncompress script from the python scripts menu. then edit the resulting file in a text editor.
My Homepage - Free stuff and Galleries
Anniebel ( ) posted Mon, 15 January 2007 at 2:11 PM
ok thanks, that must be it. They ended in z I think.
Do I uncompress from within Poser or out? Can you uncompress a single file, or have to do all?
Helen Keller
semidieu ( ) posted Mon, 15 January 2007 at 2:31 PM
You simply need to open a compressed file with Winzip (assuming you are working on Windows, else use StuffIt). Inside it, you will get the uncompressed file.
Lucifer_The_Dark ( ) posted Mon, 15 January 2007 at 2:32 PM · edited Mon, 15 January 2007 at 2:37 PM
You could use Winzip or Winrar (I'm not sure how it's done) but it's probably safer to use the script in Poser, you can uncompress a single file but it would have to be in a folder on it's own I think.
edit:
Thanks semi, I learnt something useful today :D
Windows 7 64Bit
Poser Pro 2010 SR1
thefixer ( ) posted Mon, 15 January 2007 at 2:49 PM
I always uncompress my Poser files, if you have a large HD, space isn't important!
In P7 it's Scripts/Utility/UncompressPoserFiles
I always tick "Uncompress Geometry Files" and "Delete original files after uncompressing"
It's personal choice if you want to do the last bit, but if you don't you'll have duplicates!
Injustice will be avenged.
Cofiwch Dryweryn.
lesbentley ( ) posted Mon, 15 January 2007 at 4:01 PM · edited Mon, 15 January 2007 at 4:02 PM
Attached Link: http://www.ralf-sesseler.de/d3d/
There is a handy tool "PoserCom.exe" that can be used to decompress single or multiple Poser files, folders, or groupes of folders. From the link above, go to Freebies > Samples.
Anniebel ( ) posted Mon, 15 January 2007 at 4:34 PM
Quote - You simply need to open a compressed file with Winzip (assuming you are working on Windows, else use StuffIt). Inside it, you will get the uncompressed file.
How? My winzip won't open p2z or mcz etc files
Helen Keller
Anniebel ( ) posted Mon, 15 January 2007 at 4:40 PM
Quote - I always uncompress my Poser files, if you have a large HD, space isn't important!
Thanks, I found it.
I just made a temp directory, & copied the file into it, so I could uncompress & look at it.
Helen Keller
stewer ( ) posted Mon, 15 January 2007 at 6:43 PM
Quote - How? My winzip won't open p2z or mcz etc files
Try appending .gz to the file name.
semidieu ( ) posted Tue, 16 January 2007 at 4:01 AM
Or right click on the file and choose "Open with...."
