Carrara F.A.Q (Last Updated: 2025 Feb 12 7:20 pm)
http://img.photobucket.com/albums/v141/TerraMatrix/2006-10-18019.jpg
http://img.photobucket.com/albums/v141/TerraMatrix/2006-10-18021.jpg
http://img.photobucket.com/albums/v141/TerraMatrix/2006-10-18023.jpg
That's velcro on the bottom of the pad. Pretty much I just want the model to look clean and crisp. If you need dimensions let me know. Any help I get is much, much appreciated.
bwtr
Mark That looks good BUT!
I can do the idea in the Spline modeller but without accuracy in the location/size of the holes.
I have gone to Photoshop and drawn up what I want beautifully--with the holes deleted.
But no way can I get an ai or eps file to be accepted into the Carrara spline plane.
I have done this before-is it the holes that now create the problem? HELP!
bwtr
It would have been even easier if I had a drawing to the bottom(floor) grid in the assembly room. Even without that, the grid allows exact location of different size cylinders. Then the big cylinder--all on the floor grid.
Then, back to directors camera view and ensuring the smaller cylinders are of greater height, doing tha booleen exercise seems pretty simple.
For me, it beats going via an ai file, or in the vertex or spline rooms.
Good learning exercise for me TerraMatrix. Thanks.
Lets know if you would like screen shots.
bwtr
HI bwtr, The .ai file needs to be v8 or below. I did create the Cross Section in Illustrator, saved all the holes as a group, and then created a compound path for the openings. While you can create the paths in Photoshop, Photoshop does not handle the compound path instructions. :-/ I thought PS exported paths as v3 .ai files so I'm not sure why they're not importing. Mark
I've been trying to model something for a friend, but while I might be able to render a picture alright, I can't say I model worth a darn. It's actually a really simple object, but I keep getting weird blotches all over it, and I don't know how to do a couple things. I'll put a couple shots on here so you can see what it's like.
