Sat, Jan 11, 6:45 PM CST
Subject: .OBJ to .CR2 loss of polygons??
gyusaku ( ) posted Sat, 05 May 2001 at 10:07 AM ยท edited Sat, 11 January 2025 at 4:07 PM
I am having trouble converting an .obj file that I am working on to a .cr2 file for use in poser. When I import the object into poser it looks good. So then I go to Hierarchy Editor and select the figure and the Create New Figure button and it puts a .cr2 file into the New Figures folder. The icon to select the figure looks just like the obj file but when I double click and load the image I get this mess of missing polygons and what is an all but unrecognizable figure. I am including a before and after picture in the hopes that someone has seen this kind of thing before and knows how to fix it. I am not using the poser pro pack, just version 4.0.2. Thanks in advance for any help.
Styxx ( ) posted Sat, 05 May 2001 at 2:00 PM
is it posable? if not, you could save it as a prop instead. cheers!
PhilC ( ) posted Sat, 05 May 2001 at 5:56 PM
Check your grouping and group names. Poser is very case sensitive.For example, "Tail" is not the same as "tail". If you get really stuck and you think it could help then by all means email me the files and I can look at them
bloodsong ( ) posted Sat, 05 May 2001 at 6:42 PM
heyas; do you use the grouping tool at all? it looks like you missed some polygons, or maybe those polygons weren't grouped?
gyusaku ( ) posted Sun, 06 May 2001 at 6:51 AM
Thanks guys! I had improperly grouped, but once I grouped everything, made a new prop from that, then the CR2 from the prop, everything looks good. I appreciate all the help.
