Forum Moderators: RedPhantom
There is more than one way to make toon style images. The Art Shaders are one of the best. Ockham made a script available in the freestuff here to make "Z-Toons", a kind of flattened normal renders. This is probably the easiest solution.
Cartoon Images is not posers strongest side. You can get good results, but only with fitting materials.
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
Download Daz|Studio -- toon shader is built in, no tweaking required! Just click Toon render on the render options! It's fast, easy, and does it very well, thank you!
Oh, and I usually always use Poser 6 or 7. I only use DAZ|Studio now for situations where I need to take something into Bryce or for toon rendering.
-- Jeff
I'm a real fan of Olivier's Art Shaders when it comes to creating comics in Poser:
http://www.runtimedna.com/mod/bcs/index.php?ViewProduct=2139&vendor=Olivier
http://www.runtimedna.com/mod/bcs/index.php?ViewProduct=2447&vendor=Olivier
Food for thought.....
Bantha – I did a search for “Z-Toons” and “ockham” in freestuff, but neither came up.
Jefsview – I imported a single figure into Daz Studio and tried the cartoon render – I got a grey background (which was OK) with a white silhouette of the figure. Tried a different figure and got the same result. What did I do wrong.
Aeilkema – I liked the looks of Olivier's Art Shaders, but it seems that each material has to be separately shaded and for complex scenes that could take hours or days.
Dunno. Never had that happen before. Check you camera angle and lighting. You can change the color of the background, using the tab. As far as the silhouette... like I said, never had that happen.
I know the latest D|S uses needs abit more system requirements than older versions, so check your system by using the pulldown D|S System info. It'll let you know if your computer can use it's built in shaders.
-- Jeff
Olivier's art shaders won't need applying for each figure I don't think if you use a PC, only if you use a mac as there is a freebie that comes with it, or that you candownload somewhere that applies all the materials to everything for you. Love esther
I aim to update it about once a month. Oh, and it's free!
I agree with bantha. The sketch renderer in Poser can work really well for comic renders. Plus, it's really quite flexible.
I personally find the toon render options too limiting. It essentially just adds a pre-mapped simple highlight to the textures. Sure, the results can be quite good sometimes, but other times it doesn't really seem to do much at all. A good example of this is the Steely Glare image in my gallery. This is actually a toon render!
I suppose it all depends on what you're trying to achieve. A clean manga cover-art look, or a scratchy pen and ink inner comic page look...or something in between.
BTW hold shift when you click on the toon button in the material room. This will add the effect to all parts of the selected figure. Unfortunatley I don't believe there is a way to apply this universaly to a scene.
If we can hit that bullseye, the rest of the dominos will fall like a house of cards...checkmate!
I'm sure there is a way to apply olivier's art shaders to the whole scene using the freebie that I mentioned, but I use a mac for poser so I can't say, but I hear the freebie is PC only, and I think it probably comes with the art shaders when you buy them. Love esther
Attached Link: Rosenkrantz and Guildenstern are Dead
You can get one a very flat sort of render by lighting the scene using only a single IBL at (for Poser 6/7) about 40-50%. I've linked to an image in my gallery which I used almost entirely IBL (with one infinite light at about 10%, and no AO) for the foreground figures.Yes, that does look good. Love esther
I don't think Poser 6 has a "Wacro Toon Render", does it? If so where is it?
EDIT: Just linking this thread to the one I started which lead me here. There are links in it that may be helpful to others who see this thread
say." - Ghandi
Duh! I was looking for this "wacro" thing in the render settings. It turns out it's in the material room and Poser 6 can in fact render cartoons!!!! Thanks so much Raven for the instructions on how to do this.
say." - Ghandi
I have Poser 4, 5, 6, & 7 and Paint Shop Pro X.
Is there any way to render "comic" or "cartoon" style images directly out of Poser.
I saw a product at Content Paradise, but it requires each material to be separately adjusted, and that would be a problem with complex scenes.
I saw comic and cartoon actions at this site that require only one click. They are exactly what I need, but they require Photoshop 7 or CS.
Any ideas?
