Sun, Jan 12, 3:39 PM CST
Subject: [I NEED HELP!] Poser 7 No Disk Error!
deano232 ( ) posted Wed, 24 January 2007 at 4:31 PM · edited Sun, 12 January 2025 at 3:29 PM
Ok im due a project soon which i am creating on Poser 7.
I added a few props to use in the project and when i tried to load the prop on Poser 7 into my scene this message came up:
I reinstalled Poser but i still get the same message.
Iv tried deleting the props i added and adding different ones incase it was them particular props, but again when i tried to load some of the props i added, i got the above error.
The error only appears when i try to add some props that I have added.
I need help as soon as possible because iv already created most of my project on Poser 7 and have used the Talk Designer so i wont be able to finnish it on an earlier version. :(
Iv been told it may be a problem with my hard drive? All i can say about my hard drive is this:
- SAMSUNG SP1604N/R  (160 GB, 7200 RPM, Ultra-ATA/133) -
and im running Windows.
Any help is much appreciated!***
Larry-L ( ) posted Wed, 24 January 2007 at 5:18 PM
The error message indicates you are trying to load from a disk; but your message indicates you are trying to load from your hard drive.  How did you install the prop?
YngPhoenix ( ) posted Wed, 24 January 2007 at 5:23 PM
deano232, It doesn't look like it has anything to do with your hard drive unless you're using an external hard drive for your Poser content(such as new characters,clothing, props,etc....). If that is the case then you could try moving the props into the main runtime-libraries-props location and see if that cures the problem.
nruddock ( ) posted Wed, 24 January 2007 at 5:40 PM
Check the item you tried to load for absolute paths (to textures probably).
As a quick workaround, if you have a CD or DVD drive put any disk in and the message should go away (unless the bad path is referring to the floppy drive which seems unlikely).
deano232 ( ) posted Wed, 24 January 2007 at 6:49 PM · edited Wed, 24 January 2007 at 6:52 PM
thanks for replying. I have tried putting a disk in, it lets me use poser a little longer without the error message coming up, but it still comes up.
The props i downloaded where in a ZIP file so i moved the files to the correct locations -runtime-libraries-props etc..
Im not using an external hard drive, i only have the one hard drive which the content is on and all of the content is saved in the main runtime-libraries-props location.
One thing i don't think iv installed right are the textures. I have moved the textures around into new folders in the -runtime-textures-..... to organize them, im not sure if that could be the problem.
Thanks again for the replys.
EDIT: sorry if this was posted in the wrong section!
I have just joined so havn't really looked around the forums fully.
YngPhoenix ( ) posted Wed, 24 January 2007 at 7:08 PM
deano232, No need to be sorry as you've posted in the correct section.  Poser 7 is still in its' first stages and should become less problematic when the next service releases become available. Try putting the textures into the recomended location as stated in the readme or you can usually go by how the runtime is set up when you unzip the file. I hope you get it worked out.
Inspired_Art ( ) posted Wed, 24 January 2007 at 7:18 PM
This is happening to my machine also.  Try running Adaware (check for spyware, etc)
Try seaching for "Windows - No Disk" on google. From my understanding downloading and running a program called  HijackThis should solve the problem
Eddy
deano232 ( ) posted Thu, 25 January 2007 at 10:52 AM
Thanks alot for everyone who replied. I still have the problem but if this is any help..
When the "Windows-No Disk" error is up, i went into the Windows Task Manager and clicked on applications, i right clicked on the Windows - No Disk error and clicked on go to processes.. The process which is highlighted is - csrss.exe -
TrekkieGrrrl ( ) posted Thu, 25 January 2007 at 11:09 AM
Have you successfully used that prop before? If not,t hen I'd say it's most likely (like nruddock said) a problem in the file, with a bad reference pointing to a drive YOU do not have (but the creator did)
So open the pp2 in wordpad and look for any file references.
deano232 ( ) posted Thu, 25 January 2007 at 11:14 AM · edited Thu, 25 January 2007 at 11:15 AM
Yeh i have used the prop successfully on Poser 6 and at that time i had all the same drives as i do now. Iv done some searching on google and people have had problems like this with other programs. People have said to run a scan on HijackThis.
I ran a scan and heres the Logfile if anyone can make anything of it :)
**Logfile of HijackThis v1.99.1
Scan saved at 17:05:38, on 25/01/2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.5730.0011)
Running processes:
C:WINDOWSSystem32smss.exe
C:WINDOWSsystem32winlogon.exe
C:WINDOWSsystem32services.exe
C:WINDOWSsystem32lsass.exe
C:WINDOWSsystem32svchost.exe
C:WINDOWSSystem32svchost.exe
C:WINDOWSsystem32spoolsv.exe
C:Program FilesCommon FilesAutodesk SharedServiceAdskScSrv.exe
C:WINDOWSeHomeehRecvr.exe
C:WINDOWSeHomeehSched.exe
C:Program FilesKontikiKService.exe
c:program filesmcafee.comagentmcdetect.exe
c:PROGRA~1mcafee.comvsomcshield.exe
c:PROGRA~1mcafee.comagentmctskshd.exe
C:WINDOWSExplorer.EXE
C:PROGRA~1McAfee.comPERSON~1MpfService.exe
C:PROGRA~1McAfeeSPAMKI~1MSKSrvr.exe
C:WINDOWSsystem32nvsvc32.exe
C:WINDOWSsystem32dllhost.exe
C:WINDOWSehomeehtray.exe
C:WINDOWSsystem32AGRSMMSG.exe
C:WINDOWSsystem32SOUNDMAN.EXE
C:Program FilesMicrosoft OfficeOffice12GrooveMonitor.exe
C:Program FilesAdobeAcrobat 7.0DistillrAcrotray.exe
C:Program FilesCommon FilesInstallShieldUpdateServiceissch.exe
C:Program FilesJavajre1.5.0_10binjusched.exe
C:WINDOWSeHomeehmsas.exe
C:Program FilesiTunesiTunesHelper.exe
C:Program FilesMcAfee.comVSOmcvsshld.exe
C:Program FilesInternet ExplorerIEXPLORE.EXE
C:Program FilesMcAfee.comVSOoasclnt.exe
c:progra~1mcafee.comvsomcvsescn.exe
c:program filesmcafee.comagentmcagent.exe
C:PROGRA~1McAfee.comPERSON~1MpfTray.exe
C:PROGRA~1mcafee.commpsmscifapp.exe
C:PROGRA~1McAfeeSPAMKI~1MskAgent.exe
C:Program FilesiPodbiniPodService.exe
C:WINDOWSsystem32RUNDLL32.EXE
C:Program FilesKontikiKHost.exe
C:WINDOWSSystem32spoolDRIVERSW32X863E_FATIAIA.EXE
C:WINDOWSsystem32ctfmon.exe
c:progra~1intern~1iexplore.exe
C:Program FilesMSN MessengerMsnMsgr.Exe
C:Program FilesCommon FilesAheadLibNMBgMonitor.exe
C:PROGRA~1McAfee.comPERSON~1MpfAgent.exe
C:Program FilesCommon FilesAheadLibNMIndexStoreSvr.exe
c:progra~1mcafee.comvsomcvsftsn.exe
C:Program FilesMessengermsmsgs.exe
C:PROGRA~1MOZILL~1FIREFOX.EXE
C:Documents and SettingsDeanMy DocumentsProgramsHijackThis.exe
R0 - HKCUSoftwareMicrosoftInternet ExplorerMain,Start Page = http://www.google.co.uk/
R1 - HKLMSoftwareMicrosoftInternet ExplorerMain,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLMSoftwareMicrosoftInternet ExplorerMain,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLMSoftwareMicrosoftInternet ExplorerMain,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLMSoftwareMicrosoftInternet ExplorerMain,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:Program FilesAdobeAcrobat 7.0ActiveXAcroIEHelper.dll
O2 - BHO: McBrwHelper Class - {227B8AA8-DAF2-4892-BD1D-73F568BCB24E} - c:PROGRA~1mcafee.commpsmcbrhlpr.dll
O2 - BHO: McAfee PopupKiller - {3EC8255F-E043-4cae-8B3B-B191550C2A22} - c:program filesmcafee.commpspopupkiller.dll
O2 - BHO: McAfee AntiPhishing Filter - {41D68ED8-4CFF-4115-88A6-6EBB8AF19000} - c:program filesmcafeespamkillermcapfbho.dll
O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:PROGRA~1MICROS~2Office12GRA8E1~1.DLL
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:Program FilesJavajre1.5.0_10binssv.dll
O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:Program FilesCommon FilesMicrosoft SharedWindows LiveWindowsLiveLogin.dll
O2 - BHO: AcroIEToolbarHelper Class - {AE7CD045-E861-484f-8273-0445EE161910} - C:Program FilesAdobeAcrobat 7.0AcrobatAcroIEFavClient.dll
O2 - BHO: McAfee Popup Blocker - {C68AE9C0-0909-4DDC-B661-C1AFB9F5AE53} - c:program filesmcafeempsmcpopup.dll (file missing)
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:Program FilesAdobeAcrobat 7.0AcrobatAcroIEFavClient.dll
O3 - Toolbar: (no name) - {E0E899AB-F487-11D5-8D29-0050BA6940E3} - (no file)
O3 - Toolbar: McAfee VirusScan - {BA52B914-B692-46c4-B683-905236F6F655} - c:progra~1mcafee.comvsomcvsshl.dll
O4 - HKLM..Run: [ehTray] C:WINDOWSehomeehtray.exe
O4 - HKLM..Run: [AGRSMMSG] AGRSMMSG.exe
O4 - HKLM..Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM..Run: [GrooveMonitor] "C:Program FilesMicrosoft OfficeOffice12GrooveMonitor.exe"
O4 - HKLM..Run: [Acrobat Assistant 7.0] "C:Program FilesAdobeAcrobat 7.0DistillrAcrotray.exe"
O4 - HKLM..Run: [ISUSPM Startup] "C:Program FilesCommon FilesInstallShieldUpdateServiceisuspm.exe" -startup
O4 - HKLM..Run: [ISUSScheduler] "C:Program FilesCommon FilesInstallShieldUpdateServiceissch.exe" -start
O4 - HKLM..Run: [SunJavaUpdateSched] "C:Program FilesJavajre1.5.0_10binjusched.exe"
O4 - HKLM..Run: [MAILEXTRAEXITIDLE] C:Documents and SettingsAll UsersApplication Datamemo tons mail extraDOES EACH.exe
O4 - HKLM..Run: [QuickTime Task] "C:Program FilesQuickTimeqttask.exe" -atboottime
O4 - HKLM..Run: [iTunesHelper] "C:Program FilesiTunesiTunesHelper.exe"
O4 - HKLM..Run: [VSOCheckTask] "C:PROGRA~1McAfee.comVSOmcmnhdlr.exe" /checktask
O4 - HKLM..Run: [VirusScan Online] C:Program FilesMcAfee.comVSOmcvsshld.exe
O4 - HKLM..Run: [OASClnt] C:Program FilesMcAfee.comVSOoasclnt.exe
O4 - HKLM..Run: [MCAgentExe] c:PROGRA~1mcafee.comagentmcagent.exe
O4 - HKLM..Run: [MCUpdateExe] C:PROGRA~1mcafee.comagentmcupdate.exe
O4 - HKLM..Run: [MPFExe] C:PROGRA~1McAfee.comPERSON~1MpfTray.exe
O4 - HKLM..Run: [MPSExe] c:PROGRA~1mcafee.commpsmscifapp.exe /embedding
O4 - HKLM..Run: [MSKAGENTEXE] C:PROGRA~1McAfeeSPAMKI~1MskAgent.exe
O4 - HKLM..Run: [MSKDetectorExe] C:PROGRA~1McAfeeSPAMKI~1MSKDetct.exe /startup
O4 - HKLM..Run: [NvCplDaemon] RUNDLL32.EXE C:WINDOWSsystem32NvCpl.dll,NvStartup
O4 - HKLM..Run: [nwiz] nwiz.exe /install
O4 - HKLM..Run: [NvMediaCenter] RUNDLL32.EXE C:WINDOWSsystem32NvMcTray.dll,NvTaskbarInit
O4 - HKLM..Run: [4oD] "C:Program FilesKontikiKHost.exe" -all
O4 - HKLM..Run: [NeroFilterCheck] C:Program FilesCommon FilesAheadLibNeroCheck.exe
O4 - HKLM..Run: [EPSON Stylus Photo R220 Series] C:WINDOWSSystem32spoolDRIVERSW32X863E_FATIAIA.EXE /P30 "EPSON Stylus Photo R220 Series" /O6 "USB001" /M "Stylus Photo R220"
O4 - HKCU..Run: [CTFMON.EXE] C:WINDOWSsystem32ctfmon.exe
O4 - HKCU..Run: [MsnMsgr] "C:Program FilesMSN MessengerMsnMsgr.Exe" /background
O4 - HKCU..Run: [DAEMON Tools] "C:Program FilesDAEMON Toolsdaemon.exe" -lang 1033
O4 - HKCU..Run: [hopethat] C:DOCUME~1LOCALS~1APPLIC~1ISOREM~1saveloveproc.exe
O4 - HKCU..Run: [kdx] C:Program FilesKontikiKHost.exe -all
O4 - HKCU..Run: [BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "C:Program FilesCommon FilesAheadLibNMBgMonitor.exe"
O4 - Startup: Adobe Gamma.lnk = C:Program FilesCommon FilesAdobeCalibrationAdobe Gamma Loader.exe
O4 - Global Startup: Adobe Acrobat Speed Launcher.lnk = ?
O4 - Global Startup: AutoCAD Startup Accelerator.lnk = C:Program FilesCommon FilesAutodesk Sharedacstart17.exe
O8 - Extra context menu item: Convert link target to Adobe PDF - res://C:Program FilesAdobeAcrobat 7.0AcrobatAcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert link target to existing PDF - res://C:Program FilesAdobeAcrobat 7.0AcrobatAcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert selected links to Adobe PDF - res://C:Program FilesAdobeAcrobat 7.0AcrobatAcroIEFavClient.dll/AcroIECaptureSelLinks.html
O8 - Extra context menu item: Convert selected links to existing PDF - res://C:Program FilesAdobeAcrobat 7.0AcrobatAcroIEFavClient.dll/AcroIEAppendSelLinks.html
O8 - Extra context menu item: Convert selection to Adobe PDF - res://C:Program FilesAdobeAcrobat 7.0AcrobatAcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert selection to existing PDF - res://C:Program FilesAdobeAcrobat 7.0AcrobatAcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert to Adobe PDF - res://C:Program FilesAdobeAcrobat 7.0AcrobatAcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert to existing PDF - res://C:Program FilesAdobeAcrobat 7.0AcrobatAcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:PROGRA~1MICROS~2Office12EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:Program FilesJavajre1.5.0_10binssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:Program FilesJavajre1.5.0_10binssv.dll
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:PROGRA~1MICROS~2Office12ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:PROGRA~1MICROS~2Office12ONBttnIE.dll
O9 - Extra button: (no name) - {39FD89BF-D3F1-45b6-BB56-3582CCF489E1} - c:program filesmcafeespamkillermcapfbho.dll
O9 - Extra 'Tools' menuitem: McAfee AntiPhishing Filter - {39FD89BF-D3F1-45b6-BB56-3582CCF489E1} - c:program filesmcafeespamkillermcapfbho.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:PROGRA~1MICROS~2Office12REFIEBAR.DLL
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%Network Diagnosticxpnetdiag.exe (file missing)
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%Network Diagnosticxpnetdiag.exe (file missing)
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:Program FilesMessengermsmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:Program FilesMessengermsmsgs.exe
O11 - Options group: [INTERNATIONAL] International*
O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} (McAfee.com Operating System Class) - http://download.mcafee.com/molbin/shared/mcinsctl/4,0,0,101/mcinsctl.cab
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
O18 - Protocol: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:PROGRA~1MICROS~2Office12GR99D3~1.DLL
O18 - Protocol: livecall - {828030A1-22C1-4009-854F-8E305202313F} - C:PROGRA~1MSNMES~1MSGRAP~1.DLL
O18 - Protocol: ms-help - {314111C7-A502-11D2-BBCA-00C04F8EC294} - C:Program FilesCommon FilesMicrosoft SharedHelphxds.dll
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - C:PROGRA~1MSNMES~1MSGRAP~1.DLL
O18 - Filter hijack: text/xml - {807563E5-5146-11D5-A672-00B0D022E945} - C:PROGRA~1COMMON~1MICROS~1OFFICE12MSOXMLMF.DLL
O20 - Winlogon Notify: WgaLogon - C:WINDOWSSYSTEM32WgaLogon.dll
O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:WINDOWSsystem32WPDShServiceObj.dll
O23 - Service: Adobe LM Service - Adobe Systems - C:Program FilesCommon FilesAdobe Systems SharedServiceAdobelmsvc.exe
O23 - Service: Autodesk Licensing Service - Autodesk - C:Program FilesCommon FilesAutodesk SharedServiceAdskScSrv.exe
O23 - Service: iPod Service - Apple Computer, Inc. - C:Program FilesiPodbiniPodService.exe
O23 - Service: KService - Unknown owner - C:Program FilesKontikiKService.exe
O23 - Service: McAfee WSC Integration (McDetect.exe) - McAfee, Inc - c:program filesmcafee.comagentmcdetect.exe
O23 - Service: McAfee.com McShield (McShield) - McAfee Inc. - c:PROGRA~1mcafee.comvsomcshield.exe
O23 - Service: McAfee Task Scheduler (McTskshd.exe) - McAfee, Inc - c:PROGRA~1mcafee.comagentmctskshd.exe
O23 - Service: McAfee SecurityCenter Update Manager (mcupdmgr.exe) - McAfee, Inc - C:PROGRA~1McAfee.comAgentmcupdmgr.exe
O23 - Service: mental ray 3.5 Satellite (32-bit) (mi-raysat_3dsmax9_32) - Unknown owner - C:Program FilesAutodesk3ds Max 9mentalraysatelliteraysat_3dsmax9_32server.exe
O23 - Service: McAfee Personal Firewall Service (MpfService) - McAfee Corporation - C:PROGRA~1McAfee.comPERSON~1MpfService.exe
O23 - Service: McAfee SpamKiller Server (MskService) - McAfee Inc. - C:PROGRA~1McAfeeSPAMKI~1MSKSrvr.exe
O23 - Service: NBService - Nero AG - C:Program FilesNeroNero 7Nero BackItUpNBService.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:WINDOWSsystem32nvsvc32.exe**
nruddock ( ) posted Thu, 25 January 2007 at 3:54 PM
Attached Link: http://www.whatsrunning.net/whatsrunning/QueryProcessID.aspx?Process=2
csrss.exe is an important system file (see attached link).
You need to be looking in the prop file(s) bad texture paths.
It seems likely that there is one (or more) referring to whatever drive letter your CD/DVD drive is (D: probably), so the easiest way to find the troublesome path(s) is to search for that (or "" as Poser format paths should only use ":" as the separator).
deano232 ( ) posted Thu, 25 January 2007 at 4:35 PM
thanks for the help.
i don't understand fully what to do :S
My DVD drive is D:..but what do you mean by "search for that (or "" as Poser format paths should only use ":" as the separator)"
sorry im not too good at understanding things lol
jefsview ( ) posted Thu, 25 January 2007 at 5:09 PM
I've ran into this a few times, and it's a BAD PATH FILE REFERENCE or Absolute File Reference written in the prop. I had a hellava time with it, until I ran my Poser File Organizer utility from Dimension3d. After a few runs throughs through the folders, it seemed to clear it up. Many items one downloads are written incorrectly, or are not cleaned up for distribution, including merchandise within this very store, RMP. There is another utility called Correct Reference (I don't have it, and don't have the link handy) that might be able to help you out.
I still don't know how to do these manually myself and must rely on utilities to clean up these irritating messes. But I do know that Poser File Organizer will work, or has for me in the past.
It's not Poser's problem, since I tested one of my old corrupted versions in P7 and it acted like P6. It's in the path file of the content itself.
Try out one of these utilities and help yourself out. And in the meantime, try a prop that isn't from in the same folder, i.e. from the same maker.
-- Jeff
nruddock ( ) posted Thu, 25 January 2007 at 5:14 PM
(Sorry about the double backslash the forum software usually messes with them)
The material blocks in Poser files usually contain lines like this one (a relative path) :-
    textureMap ":Runtime:textures:aDirectory:aTexture.jpg"
sometimes the "real" location of the file on the creator's machine ends up in the file, e.g.
    textureMap "D:SomeDirectoryAnotherDirectoryRuntimetexturesaDirectoryaTexture.jpg"
When Poser tries to load the texture if the path is like the above (an absolute path) it attempts to access the drive and directory mentioned, which very likely won't exist on anyone else's machine.
If the drive is a CD or DVD drive that doesn't have a disk in, Windows will complain.
What you need to do is edit the file to change the absolute path into a relative one.
The easiest way to find absolute paths is to search for ""s in the file, as the only time they are present is when there is a problem with a texture path.
nickedshield ( ) posted Thu, 25 January 2007 at 7:49 PM
An alternative search is use textureMap, then read the whole line because a folder can be mis-named even though the path is correct.
Inspired_Art ( ) posted Sat, 27 January 2007 at 11:14 AM
Also, if you purchase CorrectReference Pro from Hogsoft, it will automatically correct any bad file references, which is what you appear to have....
Eddy
