Tue, Feb 4, 5:17 AM CST
Subject: Second Skins tuts
JustMe8 ( ) posted Thu, 25 January 2007 at 9:17 AM · edited Sun, 02 February 2025 at 1:35 AM
Would anyone know of where I can find simple tuts, on how to make second skins please?
rickymaveety ( ) posted Thu, 25 January 2007 at 9:38 AM
Are you talking about second skins as in texture (painted on), or second skin type outfits that are modeled?  I ask only because it's going to make a big difference in what software you use and which tuts you will want to see.
And, what software do you have?
Could be worse, could be raining.
Acadia ( ) posted Thu, 25 January 2007 at 12:41 PM
Attached Link: http://market.renderosity.com/mod/forumpro/showthread.php?thread_id=2660658
Lots of links to tutorials on texturing and painting in that thread.  Maybe something in there will help you.  Making a second skin seems pretty much along the same lines as making a "skin" texture.
JustMe8 ( ) posted Thu, 25 January 2007 at 11:10 PM
I would like to learn how to do second skins, like what we get sometime when we purchase here and they include second skins with the character. I don't know how they do it and would have liked to learn.
ty Acadia. I had looked through there first, but have no clue what I should be starting with first.
jjroland ( ) posted Thu, 25 January 2007 at 11:40 PM
I found its actually fairly simple if the character comes with one.  Take a copy of the skin and paint on it whatever you want - then put it back in the folder and rename it what the skin texture currently in there is - of course then you have to take the original out.
This probably doesn't help you one iota, but I sure was happy with myself upon figuring it out.
I am:  aka Velocity3d
Acadia ( ) posted Thu, 25 January 2007 at 11:56 PM
http://www.renderosity.com/mod/freestuff/index.php?username=SnowSultan
First you need a seem guide.
If you are planning on making the textures and either selling them or giving them away, you can download the seam guide you need from the above link.
If you are just planning on making the second skins for yourself and not sharing them with anyone, then use a texture from your texture folder and paint over it.  To do that:
1.  Save a copy of  the texture you are going to paint over to another directory, just so you don't over write it and ruin it.
2.  Open your graphic program
3.  Browse to the texture folder and find the texture you want to paint over.
4.  Create a new layer and paing on the clothing you want to add.  Use a new layer for each part (IE; arm, leg, etc, so if you change your mind you don't have to delete everything, just the layer you don't want).
  1. Make sure you add drop shadows to embeilishments so that it adds some depth.
  2. Save the new texture using the same name as the old one (remember to save a copy of the old one to another directory).  Or you can save the new one with a different name and apply it in the material room.
7.  Make a grey scale image of the new texture.
8.  Save the grey scale image to the texture folder.
Now of course if you are starting from scratch on a blank seam guide, the steps are different because you will be also painting the skin texture not only the clothing texture onto the seam guide.
You can find information on how to paint skin textures in the links of the thread I linked you to.
rickymaveety ( ) posted Fri, 26 January 2007 at 12:09 AM
Although, it is possible to paint just a second skin outfit texture on a separate layer, and then using nodes, paste it over the skin texture in Poser.
JustMe8 ( ) posted Tue, 30 January 2007 at 12:17 PM
ty for all the help.
