Sat, Jan 18, 2:49 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 18 2:02 am)
Subject: Modeling props; draft mode vs. production mode..what's going on?
pakled ( ) posted Thu, 25 January 2007 at 9:22 PM · edited Sat, 18 January 2025 at 12:44 AM
Ok, 3rd time's the charm. Modeling a prop (yes, it does 'look like' *that* one. But it's a joke, not even close to the original in quality, etc)
Here's the original mesh, in Wings 3d. To create detail in Poser, I made the edges hard where detail was needed, beveled the 'sharp' edges by .02, and finally loop cut the puppy so that I could have more than one material to UVMap it.
pakled ( ) posted Thu, 25 January 2007 at 9:24 PM
Step 2- here's the Polearm in Draft mode. Everything's sharp and the way it should be. A little jaggy, but that's the quality setting.
pakled ( ) posted Thu, 25 January 2007 at 9:26 PM
Step 3- now, in Production mode. I get these convex surfaces on the thing, and have seen this happen before with another pic. WTF? Anyone who knows where I'm going wrong is free to point it out.
The object was imported into Poser with no changes in settings. I tried 'weld identical vertices', but no difference there.
Realmling ( ) posted Thu, 25 January 2007 at 9:32 PM
What you probably need to do is go to the properties tab on the prop and turn off smooth polys on that end.
Then it should render fine, even with smooth polys turned on in render settings.
That's generally my first step when props balloon out when rendering in Poser....and if that doesn't take care of things....uh...not sure after that atm.
Crazy alien chick FTW! (yeah....right....)
Realm of Savage - Poser goodies and so much more!
pakled ( ) posted Thu, 25 January 2007 at 9:40 PM
good ta know. I'll try it. I tried to get all the smoothing done in Wings anyways..;)
ockham ( ) posted Thu, 25 January 2007 at 9:58 PM
You can turn off polygon smoothing within the PP2 itself.
Just find the lines that go
smoothPolys 1
and make them all
smoothPolys 0
Then you won't have to worry about the render setting ever
again, and you won't have to add anything to the readme
to prevent other folks from asking you why the prop has
an aneurysm when rendered!
My python page
My ShareCG freebies
markschum ( ) posted Thu, 25 January 2007 at 10:23 PM
at the ends where the balloning occurs I wonder if you have a polygon inside the cylinder ?
If you have either remove it or unweld it.
These are syptoms of the smoothing used and is worse in firefly.
In poser 6 and up you have a dial for crease angle , that controls the amount of smoothing that occurs .
pakled ( ) posted Fri, 26 January 2007 at 8:41 PM
hmmm. I have to get it from .obj to .pp2 before I could do that. Haven't tried actually making a real prop yet, but it's probably time.
The whole thing is just extrudes and smoothing in wings. I don't think there's polys inside, but I haven't looked. I've got Poser 5, so if it works there, I'm happy.
thanks for the help. I'll see what I can do..
pakled ( ) posted Fri, 26 January 2007 at 8:49 PM
Holy buckets!..smooth polygons...how deceptively simple! I take back everything I said about you guys..;) j/k...but thanks.
