Revell had an anatomically accurate set a long while ago,as well as the Visible woman and man series... hitting the local hobby shoppe may turn one up... for the really real ones.. a medical supply centre would have one.. but at last check a human skeleton goes for about 40,000$Au... shrug Good luck
Attached Link: http://www.zygote.com
Zygote sells one, but its more "expensive". If you are serious about medically accurate skeletons see their offerings...No I meant not skeleton as in linked chains in the program, I need a poser model of a skeleton that I can move and twist in poser. Not anactual biological skeleton. When i said not in the program tense, I meant not in the "links" that connect the body. Confusing? I basically need a skeleton model for Poser. Thanx
yes he reacts pretty much the way any other poser does, you can pose him animate him give him props,.. bring the sword in, get it as close to his hand as you can then switch the camera to his hand view, then move the sword in position, then pose the hand then parent the sword to his hand. As far as animating him someone else needs to answer that- my animations always look like they are walking on land mines ;P i have some very acrobatic posers ;P
Any good skeletons out there? I need an actual skeleton, not in the program tense, but a model of human bones {skeleton} is that confusing? Thanx
