Attached Link: http://mail.curiouslabs.com/poser/magnetTutorial/magnets.html
It should texture, that's just a shadow as far as I can tell. You should spawn Morph Targets along the way as you use the magnets. Then those dials can be adjusted and new magnet effects added. Have you see this tutorial? http://mail.curiouslabs.com/poser/magnetTutorial/magnets.html -JH.Attached Link: http://morphs.bbay.com/index.html
*cough*.. looks like the Z axis is scaled larger than the X & Y ... if you reduce the Z scale that'll bring the forelock back into place.. then use a magnet to pull it.... or.. if you've already done this, reduce the size or the area of effect for the magnet,,,, THe tutorial at Curious is a good one... also check the tutes at MorphWorld CHeers. and good luckhow do you save something you've manipulated with magnets into a morph target (ie an obj file) ? i tried it with a head magnet, imported an obj and only selected the head, but something was going wrong ... when i loaded the morph target onto a new figure, the whole head moves forward from the neck and can't be brought back except by reducing the morph to zero... ie no morph! :/ i missed something?
[ Store | Freebies | Profile ]
a sweet disorder in the dress kindles in clothes a wantoness,
do more bewitch me than when art is too precise in every part
i meant exported above: i tried it with a head magnet, EXPORTED the obj and only selected the head, but something was going wrong ... when i loaded the morph target onto a new figure, the whole head moves forward from the neck and can't be brought back except by reducing the morph to zero... ie no morph! :/
oh what i did was magnets then after getting the whatever(in your case head) to how i wanted it then clicked the whatever (in your case head) then object-> spawn morph target, (that makes a parameter dial) then when you export the whatever(in your case head) make sure in your dialog box you only have the whatever selected and only have the morph target box checked. Did i confuse you yet? if not i can try again ;)
i'm sure that would make sense if i had poser open, i'll try it tonight when i get home, thanks Cheryle :) i think i tried spawn morph target before exporting the obj but i don't remember the morph target coming out as a sub-item under head though... hmmm...
