You can only see them in the shadow areas? It’s the hole render in my monitor. Les noticeable outside the Shadow areas. I would get bucket lines some times in P6 AO or not. EF never gave a answer other than something is wrong with my PC?
Can You reproduce the effect at a different bucket size. And what are the Specifications of your computer.
These are artefacts from the irradiance cache. What is the irradiance cache quality in the render settings set to? You could try increasing it and see if the lines go away. Also, the irradiance cache is less efficient when you're rendering only a small fraction of a large scene. For example, this being just a 5cm bolt in a 200m wide bridge would be such a case. If you have things outside the visible scene that are comparably large (including the ground plane), hiding them can improve things significantly.
Depth map shadows are probably set on individual lights in the first image. You might try switching to raytraced shadows for each light.
