Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 19 6:46 am)
ditto did you make the low res version? gonna make it available for us?
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
42475 vertices is not low res at all!
It is just fine and I would describe it as medium resolution .It is nice to have a lower res version of the same character.
It is sad that P7 didn't include that already! Figures that would take advantage of the best P5> feature : the smoothing option!
Would this be available somewhere?
@Deecey
Sydney is not symmetrical. I use magnets a lot on clothing and mirroring a magnet to make a morph doesn't work like it did with the older figures. Depending of the side you started on you still need to make adjustments on the other side magnets to get the clothing to fit.. A very simple one is adding the BreastNatural to clothing... do the left side mirror the magnet and you still have to tweak the settings on the right side magnet. It's been the same for every morph I've made so far
The head was reduced in Wings3D by selecting and deleting vertices manually.
The body was reduced with Polytrans. Polytrans first triangulates the mesh, then reduces it. Then the mesh was re-quadrangulated in Wings. Polytrans uses an automated reduction algorythm, so the resulting mesh is non-symmetrical.
The only way to keep her body strictly symmetrical would be to reduce it the same way as the head, by manually selecting and deleting vertices in Wings.
But because of the expression morphs symmetry for the head is a lot more important than it is for the body IMO.
Sidney LoRez is more intended for clothed characters or cloth creation, not as a standalone to develop bodymorphs for, so I reduced her body as much as possible while still looking good with polygon smoothing enabled.
If I need more body detail, I can use a medium rez version which combines the new reduced resolution head with the standard resolution body, resulting in a mesh that is 57000 vertices heavy.
I do like Sydney.
I like her face,
I like her legs and the way they bend,
I generally like her body shape too.
but boy, who made her breasts?
And - HELP- general call- who makes a low poly version of her.
E_F_ you listening? thanks.
Tony
Poser 1, 2, 3, 4, 5, 7, P8 and PPro2010, P9 and PP2012, P10 and PP2014 Game Dev
