Wed, Nov 20, 3:12 AM CST
Subject: Camera woes
rockets ( ) posted Tue, 30 January 2007 at 6:43 PM · edited Wed, 20 November 2024 at 1:29 AM
I'm really in need of some help.  I have to make an image that is 19 in. x 11 in. 300 dpi.  Poser won't render images larger than 4 thousand and something pixels so the only way I know to do this is render in halves.  I set up my scene and set my Poser screen to the right deminsions (9.5 in. x 11 in.).  Then I choose a reference point and after rendering the left half of my image I moved the camera on its x axis to the appropriate point and then rendered the right half of my image.  As you can see by this image something isn't right (notice the design on the floor).  Does anyone have any ideas what I can do to fix this or what is causing it?
My idea of rebooting is kicking somebody in the butt twice!
jerr3d ( ) posted Tue, 30 January 2007 at 7:25 PM
imho i would go ahead and do the whole scene in one render even though it is less than your idea size then in Photoshop crank the rez up and sharpen the image. the difference between 19" and 13.3" (4000 px) isn't really that much and you could prolly get away with it ^ ^
rockets ( ) posted Tue, 30 January 2007 at 7:32 PM
I may have to do that.  Thanks for the response.
jerr3d ( ) posted Tue, 30 January 2007 at 7:38 PM
but to answer your question, (a guess) the only cams that could do that would be front view or right/left view, they don't suffer from "lens distortion" if you are using the main cam, and zoom the lens to like 200mm focal length it might reduce the distortion. ( id do test renders of a lesser size first) But Poser was not designed for really large renders I think and ive seen it do some weird things one some large renders ive done >.< good luck Awesome picture!
slinger ( ) posted Tue, 30 January 2007 at 7:46 PM
jerr3d has it right...If you're using the main cam then open it up to around the 200mm mark, and render either three quarters of your image on each side and then stitch the results up in 'shop, or try doing it in 3 parts...left, center, and right and then stitching those three togther.  Hopefully the overlaps should "even out" the distortion somewhat.**
The liver is evil - It must be punished.
Angelouscuitry ( ) posted Tue, 30 January 2007 at 8:32 PM
1.) I do'nt think Poser 7 has any limit, aside from a hardware bottleneck.
I think the point behind printing beyond 72dpi(Computer Monitor Screen) is just to use more ink, for obvious reasons like durability, protection from fading, etc.
2.) Render the image as large as you can.  Then when you bring it to the Printer, have him or her RIP(Rasterize(?) it with his/her RIP machine; because you want it printed at 300dpi(regardless of what it's at when you give it to him.)
3.)  Photoshop can also increase the pixel count of your image, similar to RIP software; but through Interpolation.  I'm not sure which mathematical process is visibly better, but I am pretty sure they both do a relatively good job.
rockets ( ) posted Tue, 30 January 2007 at 10:21 PM
Thanks for all the input.  I should have known there's no easy solution to this problem. :unsure:
rockets ( ) posted Tue, 30 January 2007 at 10:59 PM
I think I'm inclined to try jerr3d's first suggestion, but would somebody please tell me the correct demensions so I can enlarge back to 19 x 11 in PS?  Jerr3d said 13 wide so what height?  (Yes, now you all know the extent of my ignorance :blushing:).
jerr3d ( ) posted Tue, 30 January 2007 at 11:41 PM
sure rockets, under Render Dimensions: a) Render to exact resolution b) Match document window c) Width 4000px (and the height should change automatically) d) Resolution 300 then Render, it will take awhile
Angelouscuitry ( ) posted Wed, 31 January 2007 at 7:37 AM
I do'nt have Poser open here, but I think another possible solution would be to make your Document Window 3300 x 5700; then just Plop Render; move the view, and plop render, move the view and Plop Redender, etc, etc, (about 20 times.)  When you are done you can then composite all of the parts, in Photoshop, without any distortion.
rockets ( ) posted Wed, 31 January 2007 at 8:48 AM
Thank you all for your thoughts and taking time to respond.  I'm going to have to make 13 images at this size so I'm looking for the most painless way of doing it.  That being said, I think jerr's first solution will work out the best.  I tried it and it really doesn't look bad at all.  You have to keep in mind that the humongous render doesn't look that huge when you check out the print size in PS.  When I get an image put together, I'll post some area check images so you can see what it looks like at the print size and at the actual size if anyone is interested.
