Sun, Feb 2, 4:37 PM CST
Subject: Image resolutions in Bryce
Ice8 ( ) posted Mon, 07 May 2001 at 4:54 PM ยท edited Sun, 02 February 2025 at 4:34 PM
Can somebody tell me how to get my Bryce renderings to come out at a higher resolution than 72dpi? I would love to print some of my work, but at 72dpi, prints look awful. Poser allows you to set the render resolution in dots-per-inch, but no matter what render resolution I pick in Bryce (1:1.50, 1:2.00, etc.) it always ends up being 72dpi. Waddup?
clay ( ) posted Mon, 07 May 2001 at 5:18 PM
Select Render to disk under your file menu, then a box appears where you can set output size and resolution.
Do atleast one thing a day that scares the hell outta ya!!
Ice8 ( ) posted Mon, 07 May 2001 at 5:22 PM
Wow, cool! Thanks a bunch, Clay! I knew it was something simple!
clay ( ) posted Mon, 07 May 2001 at 5:23 PM
You're very welcome:-)
weirdass ( ) posted Mon, 07 May 2001 at 8:33 PM
Attached Link: http://www.weirdass.net
Other than the render to disc option- remember- 300 pixels per inch isn't just hires, its 300 pixels. ie Hires file for a 4x4 inch print is 1200 dpi. Work at 400x400 and render it with the 1:3 option. phoshop will allow you to change res. Just use a calculator. Mitch
EricofSD ( ) posted Mon, 07 May 2001 at 11:00 PM
You can double click the render button and select a higher resolution if you want to render to ram. The default format is good for posting here and a reduction for thumbs is in order. There are some folks who choose very high resolution to print to poster size. Good luck.
dg3d ( ) posted Tue, 08 May 2001 at 8:44 AM
Attached Link: http://www.ggp.qc.ca/pleiades/index.htm
It depend on what kind of print you want. What settings you will put to your printer. The best is if you print like a 4x6 photo paper, just do the render around 150 dpi and the inch, type 4 in the first box then render. I am doing a faq on render to print what to do at my web site. I am try to put it this week, almost finish. You can bookmark the address, or email me. i can give more info.
Stuie ( ) posted Wed, 09 May 2001 at 12:50 AM
For my animations, the frames have to be rendered at a final resolution of 400 dpi at 8.25" x 4.25" (3300 pixels x 1700 pixels). All I do is render with the document size at 3300 x 1700 which comes out to 45.83" x 23.61" (at 72 dpi). I then adjust the image in PhotoShop by making the dpi 400 and the size 8.25" x 4.25". Basically, the picture doesn't change because it is still only 3300 x 1700. Does this make sense? PhotoShop makes it easy to do with the Actions feature. You just record your steps in the action feature, then use it again for multiple frames.
