Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 1:08 pm)
You effectivly make a movie of a single frame with the render settings set as the Preview Window.
Hope this helps.
Quote - - Set the display setting to Wireframe.
- Now go to AnimationMake Movie.
- In Format select Image Files.
- In Render select Preview
- In Options select Anti Alias.
- In Resolution set the size of your image.
- In Time Span set Start and End Frame to 1
- Click the Make Movie button.
Hope this helps.
I'm not 100% certain (can't check right now) but could you not also do this using "Preview" in normal (single-frame) render settings?
Yes, it doesn't need to be rendered as a single frame movie clip, you just select the Preview renderer from the render settings, and check antialiasing there. Document render size is then controlled via the usual dialogue.
Adam :)
Adam Benton | www.kromekat.com
I am trying to find the right setting to render out my Figure as a Wireframe Figure ... Only can find Sketch,Cartoon and the usual stuff ... I only can see my Figure as Wireframes in my Preview Window
any help is much appreciated
cheers
ChromeD
