Wed, Feb 26, 2:24 AM CST
Forum Moderators: RedPhantom
Subject: Can`t understand "Magnetize to" with V4
factor ( ) posted Fri, 16 February 2007 at 4:07 AM · edited Wed, 26 February 2025 at 2:19 AM
Hi there,
may be this is a stupid question, if i do something wrong with all this.... but please help me somebody.
I understand the "Magnetize to"-Thing like this:
1st  - i conform my clothes as usual to V4
2nd - I apply the Magnetize to to the desired clothes
3rd  - Now Pser added new dials to the palette which should morph the clothes
But... whatever i do with the dials.... nothing happens with the clothes.
In this example i used Alice by Aerysoul. But my problem exists also with the normal V4.
Can someone explain what i have to do, or has someone a link to a tutorial?
Many thanx, Factor
martial ( ) posted Fri, 16 February 2007 at 4:47 AM
I am also not sure i really understand this new feature too.May be someone can explain it  with a tutorial
thefixer ( ) posted Fri, 16 February 2007 at 5:24 AM
Injustice will be avenged.
Cofiwch Dryweryn.
factor ( ) posted Fri, 16 February 2007 at 5:55 AM
**Thanx Fixer!
**I`ve read that....
QUOTE:
***3. Simply double-click on this pose and the selected clothing item will automatically be influenced by the D-Formers just like the underlying figure.
***I did that, yes... buteven if then are new dials...there is nothing changing when i use them!!!!
And nothing fits "automatically"!!!
Its really a mess....
But thanx for the link!
Factor
Xena ( ) posted Fri, 16 February 2007 at 6:01 AM
Layman's terms ....
Victoria 4 contains many magnets that replace a lot of the old JCM (joint controlled morphs) that previous Daz figures had to make them bend better. Using the !Magnetise To V4 adds these magnets to your clothing so that it bends better as well. You do not manually adjust these new magnets, they are tied into Victoria 4's joints so that when she bends a particular way, certain magnets are activated to make that bend better.
Magnetise DOES NOT add morphs to your clothing, make other character fit into your clothing, add full body morphs to your clothing, give you the ability to dial her boobs up to gigantic proportions and get no poke thru, clean your dishes or make you coffee :)
jjroland ( ) posted Fri, 16 February 2007 at 10:22 AM
I can't understand why they can't just make it easy to make clothes fit.  The lengths I have to go to is absurd.
I am:  aka Velocity3d
factor ( ) posted Fri, 16 February 2007 at 11:54 AM
QUOTE MYSELF:
***But... whatever i do with the dials.... nothing happens with the clothes.
So.... what the hell are DIALS FOR..... if they have ***NO EFFECT????????
Factor
pobble ( ) posted Fri, 16 February 2007 at 1:32 PM
At least part of this is discussed in : http://forum.daz3d.com/viewtopic.php?t=52973 (read all the postings to get the idea) It's about DazStudio but I think it's the same thing.
svdl ( ) posted Fri, 16 February 2007 at 1:39 PM
Try this for example:
  • Load V4
  • Load a conforming shirt or vest, conform it to V4, and magnetize it to V4
  • Select the V4 figure and use the BreastUpL morph (I'm choosing one of the breasts morphs not out of a certain fixation, but because the effect is the most visible).
    You'll see that the clothing will follow V4's breast.
    -Now select that shirt and turn the V4LBreastUpIn dial to zero
    You'll see that the cloth no longer "follows" the breast.
The dials on the clothing tell you how strong the V4 magnets influence the cloth. Almost always the values should be left at 1.000.
jjroland - this feature actually makes it easier to make conforming clothes for V4. No need to make tons of joint controlled morphs, the magnets will take care of it. No problems with unwanted crosstalk in P4/PP. No problems with non-functioning ERC in Poser 5 and up. The more I play with V4, the more I like her.
My gallery   My freestuff
jjroland ( ) posted Fri, 16 February 2007 at 2:58 PM
Saw those magnets once in p6 - haven't been able to find them since - maybe that is my problem.
Xena ( ) posted Fri, 16 February 2007 at 6:03 PM
Quote - I can't understand why they can't just make it easy to make clothes fit.  The lengths I have to go to is absurd.
They don't make clothes fit. They make the clothing move with V4 as she bends and moves her limbs.
jjroland ( ) posted Fri, 16 February 2007 at 6:13 PM
"They" as in poser - creators of these programs.
Xena ( ) posted Fri, 16 February 2007 at 6:27 PM
The makers of Poser really don't have anything to do with how clothes fit either. It's the clothing creator's skill that determines how well clothing fits.
Clothing 'out of the box' should fit Victoria 4. If it doesn't you should return it and get your money back, or if it's a freebie throw it away. I honestly don't understand why so many people have trouble fitting clothing to V4. The only thing I can think is if they are turning dials on V4 that aren't matched in the clothing. And that, once again, is because of the clothing creator. Personally, I don't match every single morph, only the FBM ones, as to match every single morph would take a ridiculous amount of time and I'd have to raise my prices to cover the extra work put in.
