Manuel does not tell me how to make a external Runtime that I know of.
So how do we make a external Runtime ?
Thanks
RorrKonn
http://www.atomic-3d.com
The
Artist that will fight for decades to conquer their media.
RorrKonn, the V3RR that is part of the special free D|S Content is in Studio native format.
You cannot use it in Poser as Poser cannot read .daz, .ds, .dsb, or data files.
Your only other option would to be to buy the V3RR with the necessary .cr2 to work in Poser:
www.daz3d.com/i.x/shop/itemdetails/-/
Oh kool
Thay have a M3 Reduced Resolution also
I searched DAZ for a A3 Reduced Resolution.
Ya know if there is A3 Reduced Resolution ?
RorrKonn
The
The
If DAZ|Studio can export to .OBJ files, you can try the following:
load V3 RR LE in DAZ|Studio
make sure she is in absolute zero pose (all rotations and translations set to zero, all scales at 100%, all inverse kinematics off)
export her as Wavefront .OBJ file
import the Wavefront .OBJ file in Poser
switch to the Setup room
apply the V3 figure from the Figures library
switch back to the Pose room
save the figure to your Figures library.
Now you'll have a V3 LE figure, but without any morphs. If you want those morphs too:
Again, this will ONLY work if DAZ|Studio can export to .OBJ format. I wouldn't be surprised if that's not possible. DAZ will want you to buy the V3 RR figure for Poser and may have taken steps to prevent the user from getting V3 RR into Poser this way.
Keep it on the low down, Don't give DAZ any idea's ;)
10 minutes after downloading DAZ Studio I had V3 RR LE in C4D.
DAZ Studio Exports .obj .bvh. Imports Poser stuff.
Killer directions, Very helpful.
Thanks
RorrKonn
The
How do ya get DAZ Studio meshes inside Poser with out losing anything ?
I just got DAZ Studio it done a search and found all the Poser files and all the Poser files work in DAZ Studio.
Just like thay work in Poser.
I am trying to get the low polycount 24406 V3 RR LE that comes with DAZ Studio in side Poser.
I know I could import it as a .obj but it would lose everything.
Anyway to get DAZ Studio meshes to work in Poser like Poser meshes work in DAZ Studio ?
Thanks
RorrKonn
