Do you have multiple versions of Poser installed?
Also make sure that you install everything you are trying to import within the Runtime folder of Poser 6, as Vue may be trying to locate geometries etc in Poser Runtime that are actually in the DAZ Runtime.
I know that Poser 7 and Vue Infinite (which I use) do not always see eye to eys on paths and so on, esp if a pz3 file has been opened with different versions of Poser.
Apart from that I don't know what else to suggest.
Note also that DAZ|Studio has a placeholder file called "poser.exe" that might mis-identify to Vue as actually being Poser.
Yes this is very frustrating. Just got another prop that won't import 'EvilInnocence Ribbon' from Renderosity. I've done all of the above. As well as this I haven't got the DAZ programme, I just use a lot of their figures - I find they are the ones most likely to import into VUE infinte from POser without any trouble. Is there anything else i can try? I am using a runtime titled Runtime 7 which is inside Poser 6. This is because I installed poser 7, found it too buggy, so I moved the p7 runtime back into poser 6. It seems to work fine for most things any ideas?
I am having trouble importing Cubed'd Jenny baby figure from Poser 6 into Vue Infinite. I've been trying to import it as a pz3 but nothing appears..? Any ideas what the problem could be? Or could you point me in the way of previous threads/tutorials? Any advice gratefully received?
