Fri, Nov 15, 6:34 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 4:06 am)
Subject: Lightwave and Poser.
AntoniaTiger ( ) posted Tue, 27 February 2007 at 2:47 PM · edited Fri, 15 November 2024 at 6:33 AM
Poser will import some Lightwave meshes. Does anyone know for sure what the version-number limit is? And I've found some nice tank models, but they seem to be a set of component meshes, which Poser will import, with a file detailing where the components are used. A hundred or so track links from the same mesh data is OK, but getting that into Poser is heavy work.
flyerx ( ) posted Wed, 28 February 2007 at 12:46 AM
Attached Link: http://mysite.verizon.net/sfg0000/
I believe it is limited to version 5.
Although it does not read Lightwave scenes (LWS) you can try PoseRay for newer LWO meshes. It uses the current object file format specification from Newtek.
good luck,
FlyerX
wheatpenny ( ) posted Wed, 28 February 2007 at 1:03 AM
Site Admin
If you have deep exploration, it can open LWO's and LWS's up to version 8 and convert them to obj or 3ds
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
