Wed, Nov 27, 12:54 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 27 12:30 pm)
Subject: InterPoser Pro to .fbx (filmbox) format? Poser to EIAS?
danb ( ) posted Sat, 03 March 2007 at 10:02 AM · edited Wed, 27 November 2024 at 12:35 PM
I need to be able to import a poser scene into Electric Image Animation System.  The way i was thinking of doing this is to use InterPoserPro in c4d and export that as a .fbx, to import into EIAS.
Anyone have any ideas on how to get poser scenes into EIAS?
kuroyume0161 ( ) posted Sat, 03 March 2007 at 2:27 PM
interPoser Pro currently won't let you do this in C4D as the bones are proprietary (my own plugin bones) and are not understood by C4D for such purposes.  That said, there will be a feature to convert these bones into standard C4D bones or joints in the near future.  This would allow FBX export using C4D.
For now, though, your best bet would be to get Daz|Studio, purchase the FBX plugin for it, and use that instead.  The downsides are:
  1. I've not heard great things about the FBX export results.
  2. It's $99.95.  If you were a Daz PC member, you could have had it for $1.99 just a couple days ago!
 -- Bjarne Stroustrup
danb ( ) posted Sat, 03 March 2007 at 2:35 PM
Thank you.  Do you have a time table for when the interposer object to bones may be released?  Its too bad i missed that special for Daz/3d.  Maybe $100.00 is still not too expensive.
danb ( ) posted Sat, 03 March 2007 at 3:27 PM
Any idea why i can't import my poser 7 scenes into Daz/3D?  Does it support poser 7?  I didn't check. :(
kuroyume0161 ( ) posted Sat, 03 March 2007 at 4:00 PM
D|S doesn't support most of the features of Poser 7 (esp. PMD (external binary morphs) and Animation Layers).  If not doing any animation, try turning off 'use external binary morph targets' in the Poser General Preferences:Misc. and resaving the scene.  This might allow it to import.  Also make sure that your Poser 7 Runtime is known to D|S for dereferencing (geometry, texture maps, etc.).
No idea when the bone conversion will be implemented.  Currently working on Recent Lists and Favorites (not too much work) and then IK and PointAt support are slated next.  Bone conversion is after these, so it may be some months.
danb ( ) posted Sat, 03 March 2007 at 4:05 PM
Ok thank you.  I will try those suggestions.  No problem about the bones.  Hopefully D|S will save the day.
I am trying to export animations from D|S using .fbx.  I hope i can figure out how to do that.
nruddock ( ) posted Sat, 03 March 2007 at 7:02 PM
Quote - Any idea why i can't import my poser 7 scenes into Daz/3D?
You have to delete the lights before trying to load a PZ3  saved with P7into D|S, because a change in the way they get saved confuses D|S (I don't know if P7 SR1 has removed the need to do this).
