Tue, Oct 22, 8:32 AM CDT
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Adjust feet in Poser animation
Nebula ( ) posted Sun, 04 March 2007 at 10:24 AM · edited Tue, 22 October 2024 at 6:33 AM
Hello,
  Is there any kind of python script around that will automate the adjustment of a characters' feet in Poser.  I have an animation that is 1000 frames long.  I also have the model wearing heels.  The heel product came with a "feet pose" to adjust the feet fit the heels.  What I would like is for the script to go thru each frame and basically click the "feet pose" button automatically.  I hope this makes sense.  Does something like this exist?  If not, I am a programmer by trade.  Would there be any good place to look to figure it out for myself?
 Thanks,
Nebula
svdl ( ) posted Sun, 04 March 2007 at 10:42 AM
Attached Link: http://www.svdlinden.nl/webposerstuff/downloads/footbends.zip
Here are two scripts that I wrote a long time ago. If you combine them and tweak a little, you can make the script you're looking for.
My gallery   My freestuff
Nebula ( ) posted Sun, 04 March 2007 at 11:05 AM
Wow, thanks!  I will look at them right now.
Your the man today! lol
Nebula
Nebula ( ) posted Sun, 04 March 2007 at 3:17 PM
I am messing around to learn how Python works.  Having a problem tho....
Question:  What am I doing wrong here??  Error highlighted in code below.....
(Also, how do I rename the character from "Victoria 4" to "JoJo" in the GUI list?)
Error: Traceback (most recent call last):
            File "D:GraphicsPoser 7RuntimePythonCreate_JoJo.py", line 18, in ?
            LeftHeel.SetConformTarget(JoJo)
            AttributeError: 'str' object has no attribute 'SetConformTarget'
Python Code:
*scene=poser.Scene()
scene.LoadLibraryFigure("D:GraphicsPSR-DLCV4-DLCRuntimelibrariescharacterVictoria 4Victoria 4.cr2")
fig=scene.CurrentFigure()
JoJo=fig.Name()
scene.LoadLibraryPose("D:GraphicsPSR-DLCV4-DLCRuntimelibrariesposeJoJo!!jojo_morphINJ.pz2")
scene.LoadLibraryPose("D:GraphicsPSR-DLCV4-DLCRuntimelibrariesposeJoJo!jojo_texture.pz2")
scene.LoadLibraryPose("D:GraphicsPSR-DLCV4-DLCRuntimelibrariesposeJoJomu_2.pz2")
scene.LoadLibraryPose("D:GraphicsPSR-DLCV4-DLCRuntimelibrariesposeAll the Right MovesARM - 115a.pz2")
scene.LoadLibraryFigure("D:GraphicsPSR-DLCV4-DLCRuntimelibrariescharacterHard-Sole SandalsV4HardSoleSandal01 L.cr2")
LeftHeel=fig.Name()
scene.LoadLibraryPose("D:GraphicsPSR-DLCV4-DLCRuntimelibrariesposeHard-Sole Sandals!Show_Ring.pz2")
scene.LoadLibraryPose("D:GraphicsPSR-DLCV4-DLCRuntimelibrariesposeHard-Sole SandalsMAT_01.pz2")
LeftHeel.SetConformTarget(JoJo)  < Problem Line
scene.LoadLibraryFigure("D:GraphicsPSR-DLCV4-DLCRuntimelibrariescharacterHard-Sole SandalsV4HardSoleSandal01 R.cr2")
RightHeel=fig.Name()
scene.SetConformTarget(JoJo)*
svdl ( ) posted Sun, 04 March 2007 at 3:35 PM
The problem arises from the line "LeftHeel=fig.Name()" LeftHeel is just a string.
Replace the lines
LeftHeel=fig.Name()
and
with
LeftHeel=scene.CurrentFigure()
and
RightHeel=scene.CurrentFigure()
This will make sure that LeftHeel and RightHeel are figure objects, not strings. Figure objects have a SetConformTarget method.
Since SetConformTarget takes a figure object as argument, you also should change the line
JoJo=fig.Name()
into
JoJo=scene.CurrentFigure()
Hope this helps,
Steven.
nruddock ( ) posted Sun, 04 March 2007 at 3:37 PM
Quote - I am messing around to learn how Python works.  Having a problem tho....
Based on your code snippet, you need to use fig.SetConformTarget(JoJo) in both places where you're trying to conform an item.
svdl ( ) posted Sun, 04 March 2007 at 3:48 PM
Setting a figure's name:
  • from Python:
fig.SetName("")
  • from the user interface:
    choose Object->Properties, select the Body actor, switch to the Properties tab and enter your name. Confirm with
Nebula ( ) posted Sun, 04 March 2007 at 8:37 PM
Steven,
  The python command fig.SetName("") doesn't work.  I don't believe SetName is a valid method for a figure.  There is one for an Actor, but not for a Figure.  Or else I am missing something.  I was able to get the rest to work just great....... after several tries that is.  But, I'm learning!
  Thanks for your help!!
Doug
