Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Attached Link: http://www.svdlinden.nl/webposerstuff/downloads/footbends.zip
Here are two scripts that I wrote a long time ago. If you combine them and tweak a little, you can make the script you're looking for.The pen is mightier than the sword. But if you literally want to have some impact, use a typewriter
I am messing around to learn how Python works. Having a problem tho....
Question: What am I doing wrong here?? Error highlighted in code below.....
(Also, how do I rename the character from "Victoria 4" to "JoJo" in the GUI list?)
Error: Traceback (most recent call last):
File "D:GraphicsPoser 7RuntimePythonCreate_JoJo.py", line 18, in ?
LeftHeel.SetConformTarget(JoJo)
AttributeError: 'str' object has no attribute 'SetConformTarget'
Python Code:
*scene=poser.Scene()
scene.LoadLibraryFigure("D:GraphicsPSR-DLCV4-DLCRuntimelibrariescharacterVictoria 4Victoria 4.cr2")
fig=scene.CurrentFigure()
JoJo=fig.Name()
scene.LoadLibraryPose("D:GraphicsPSR-DLCV4-DLCRuntimelibrariesposeJoJo!!jojo_morphINJ.pz2")
scene.LoadLibraryPose("D:GraphicsPSR-DLCV4-DLCRuntimelibrariesposeJoJo!jojo_texture.pz2")
scene.LoadLibraryPose("D:GraphicsPSR-DLCV4-DLCRuntimelibrariesposeJoJomu_2.pz2")
scene.LoadLibraryPose("D:GraphicsPSR-DLCV4-DLCRuntimelibrariesposeAll the Right MovesARM - 115a.pz2")
scene.LoadLibraryFigure("D:GraphicsPSR-DLCV4-DLCRuntimelibrariescharacterHard-Sole SandalsV4HardSoleSandal01 L.cr2")
LeftHeel=fig.Name()
scene.LoadLibraryPose("D:GraphicsPSR-DLCV4-DLCRuntimelibrariesposeHard-Sole Sandals!Show_Ring.pz2")
scene.LoadLibraryPose("D:GraphicsPSR-DLCV4-DLCRuntimelibrariesposeHard-Sole SandalsMAT_01.pz2")
LeftHeel.SetConformTarget(JoJo) < Problem Line
scene.LoadLibraryFigure("D:GraphicsPSR-DLCV4-DLCRuntimelibrariescharacterHard-Sole SandalsV4HardSoleSandal01 R.cr2")
RightHeel=fig.Name()
scene.SetConformTarget(JoJo)*
The problem arises from the line "LeftHeel=fig.Name()" LeftHeel is just a string.
Replace the lines
LeftHeel=fig.Name()
and
with
LeftHeel=scene.CurrentFigure()
and
RightHeel=scene.CurrentFigure()
This will make sure that LeftHeel and RightHeel are figure objects, not strings. Figure objects have a SetConformTarget method.
Since SetConformTarget takes a figure object as argument, you also should change the line
JoJo=fig.Name()
into
JoJo=scene.CurrentFigure()
Hope this helps,
Steven.
Setting a figure's name:
fig.SetName("")
Steven,
The python command fig.SetName("") doesn't work. I don't believe SetName is a valid method for a figure. There is one for an Actor, but not for a Figure. Or else I am missing something. I was able to get the rest to work just great....... after several tries that is. But, I'm learning!
Thanks for your help!!
Doug
Hello,
Is there any kind of python script around that will automate the adjustment of a characters' feet in Poser. I have an animation that is 1000 frames long. I also have the model wearing heels. The heel product came with a "feet pose" to adjust the feet fit the heels. What I would like is for the script to go thru each frame and basically click the "feet pose" button automatically. I hope this makes sense. Does something like this exist? If not, I am a programmer by trade. Would there be any good place to look to figure it out for myself?
Thanks,
Nebula
