Tue, Jan 7, 8:07 AM CST
Subject: Fitting hair to Aiko and Hiro realistic morph?
vincebagna ( ) posted Sun, 04 March 2007 at 10:49 AM · edited Sun, 05 January 2025 at 7:47 PM
Hi!
 How can i fit hair to Aiko and Hiro with their realistic morphs on? When hair props have "fit Aiko/Hiro", it's only for their cartoon big head.
And another question:
i know Wardrobe Wizard fit cloths from a character to another one, but does it work with hair too?
hanks, cause it's a big headache to always see my Aiko and Hiro completey bald, and they could get  cold too :)
thefixer ( ) posted Sun, 04 March 2007 at 12:02 PM
I have hair that will fit whatever Aiko I use, if not just use the scale dials!
Injustice will be avenged.
Cofiwch Dryweryn.
vincebagna ( ) posted Mon, 05 March 2007 at 1:37 AM
Ok, but which hair do you have that fits both Aiko?
pjz99 ( ) posted Mon, 05 March 2007 at 1:48 AM
Wardrobe Wizard does have an option to convert "As Hair", although I've never actually used it.
In the case of longer hair it's not a big deal to adjust x/y/z scaling to fit the front and top and sides of the head, although getting short hair to grab the bottom of the skull can be a pain.
My Freebies
MartinW ( ) posted Mon, 05 March 2007 at 2:28 AM
FWIW I've found most of Koz's hair works with a little scale and movement - generally + the X scale and - the Z transation - and a lot of his P4 Posette hair works really well with Aiko too
I don't use Hiro too much (currently) so can't really say about him...
thefixer ( ) posted Mon, 05 March 2007 at 2:45 AM
Vince: I'm at work right now, as soon as I get home I'll give you an answer, I'm pretty sure that most hair that fits Aiko has a dial for "Realistic" that usually sets to 1
Cofiwch Dryweryn.
vincebagna ( ) posted Mon, 05 March 2007 at 5:26 AM
I hope someone will find a solution, cause Aiko looks very silly with hair floating above her head :)
thefixer ( ) posted Mon, 05 March 2007 at 5:43 AM
Vince: Like I said, most hair props/characters for Aiko do have a setting for "realistic", I don't know about that particular hair 'cos I don't have it.
That said, looking at your image, if it doesn't have the setting, that could be made to fit easily enough using the xyz scale dials and the xyz position dials.
I have done this many times with hair fits for V4 for example where there is no V4 version of a hair, I have dialled it to fit.
It's not always perfect but any mismatch can be hidden depending on your pose, for example if you can't see the back of the head, who cares if it's not right there as long as the front and / or sides looks right!!
What you can't see doesn't matter!!
Cofiwch Dryweryn.
vincebagna ( ) posted Mon, 05 March 2007 at 5:57 AM
Thanks for the advice, but i have also hair that are supposed to fit several characters, and for Aiko then, there is only 1 setting to fit to "big head" Aiko.
I found some stuff that fit hair for almost all characters, but the same for Aiko and Hiro, only "big head".
thefixer ( ) posted Mon, 05 March 2007 at 6:17 AM
Vince: I'm trying to help you here buddy, but I don't have access to Poser here, I'll be home in about 3 hours and I'll supply a list for you of hair that "does" have a "realistic" fit for Aiko.
In the mean time, please try the scale and position dials on this particular hair, it does work, there are many here that use this method!
Cofiwch Dryweryn.
thefixer ( ) posted Mon, 05 March 2007 at 10:31 AM · edited Mon, 05 March 2007 at 10:31 AM
Attached Link: http://www.3dcommune.com/
I have a lot of hair stuff but only 3 as it turns out have the "realistic" setting and are as follows:
Amarseda from DAZ
FK Twins from 3DC.
Nyoko hair from DAZ
I'm pretty sure that all if not most of the Aiko hair at 3DC will have this setting!
Cofiwch Dryweryn.
pjz99 ( ) posted Mon, 05 March 2007 at 11:16 AM · edited Mon, 05 March 2007 at 11:17 AM
I'd expect that problem could be fixed with magnets, or with the joint editor since the hair appears to be a conforming figure (move the joint centers for left and right shoulder down).  You might also try converting in Wardrobe Wizard if you have it.
Another solution is to simply not conform the hair, but instead just parent it to the head, and pose it manually with morphs or joint bends.
My Freebies
thefixer ( ) posted Mon, 05 March 2007 at 11:33 AM
It really doesn't need to be that difficult, If it's conforming just don't conform it.
Fit it to the head, scale and position it to your liking and then parent it to the head, job done!!
Cofiwch Dryweryn.
vincebagna ( ) posted Tue, 06 March 2007 at 2:31 AM
Sorry not to reply, it was my turn to be at work :)
So i decreased general scaling and it seems to fit. But i wonder if it would be so easy with hair like Koz because of the front of the head which has to fit well with the base of the hair.
And is it possible to copy the "realistic fitting" that is in the hair for Aiko, to become a general fitting, ready to use with all other hair that fit her "big head"?
It's surely posible to have a magnet or morph stuff you have just to click on to get the hair resize to her realistic head morph, like in her cloths. But i'm not good enough with morphs and magnets to fix that (honestly, i never use them... ;) )
But perhaps someone good enough with that could make a try?
vincebagna ( ) posted Tue, 06 March 2007 at 2:45 AM
Attached Link: hair conversion kit
In addition, you can downlod for free the Hair Conversion Kit from Netherworks Studios that fit hair to all Mill figures. Could be useful!
And for The Fixer, the hair i used on Aiko is Akashi hair for Aiko and V3.
pjz99 ( ) posted Tue, 06 March 2007 at 2:47 AM
Short answer is no, there isn't going to be a single pose or other setting you can apply to every hair to make it fit a given figure.  Each hair is going to have very different geometry, some will be conforming and some will not, etc.  The morph slider you are used to with clothing to reshape between different figure morphs is something designed into each and every item you own that has that morph, and items that don't have it built in would need to be converted, each and every one, separately.  Or you could just figure out how to parent a hair to a head and stop worrying about conforming...
My Freebies
rockets ( ) posted Tue, 06 March 2007 at 4:58 AM · edited Tue, 06 March 2007 at 5:02 AM
As theFixer keeps saying, it's not hard.  I fit any hair to any character.  If it's a hair prop just turn the dials until it fits and then lock it so it doesn't move after you pose the character.  If it's a conforming figure do this.  Keep your Aiko (or whoever) in the default position.  Load the conforming hair (don't conform it) and then turn the dials until it fits. Then go to figures "set figure parent" and select head from the list.  With the character selected, pick the hair body (this is important), go up to object and lock it so it's doesn't move when posed.  These directions are for Poser4 so just do the above for any version of Poser you're using.  P.S - after posing you'll have to unlock to be able to move the morphes around and then remember to lock it again.
My idea of rebooting is kicking somebody in the butt twice!
