Right to make sure it wasnt anything like a firewall or antivirus i turned them off and rebooted without them... and still Poser 7 firefly renders blank, so there is nothing stopping it.... does anyone know if there is a solution to this.... as now im going to have to re-install P7 without the SR1 update..... grrrrrr
Getting old and still making "art" without soiling myself, now that's success.
I have tried rendering a simple sphere, then a cube, as well as V4 with trimmings and another with aiko3 all were blank...
my system specs are similar to those posted in the first comment...
im now about to re-install P7 and avoid SR1.... so no more saving in .jpg for me...lol
i never had rendering in a seperate process on and i tried rendering with the basic options as well as with shadows etc on... and still no joy... i have now returned my P7 back to its JPG hating old pre SR1 self, at least it renders...lol
Perhaps SR2 will work.... or maybe P7 will be my downfall.... and i should wait till P8 lol
But that's not all, the Hardware shading enabled thingie isn't working properly either. Not that I expected it to be fully fixed but the new look is something else: load V4, apply a texture that uses shader nodes (ie the V4 Hi Res texture by DAZ or Alice by Aery Soul). Looks like this. Happens with clothing textures that are using shader nodes as well. I have to render once or only render a small part to make it look normal. But that can't be the solution.
And still P7 exchanges the transparency map with the texture map on some hair and I have no idea why it's doing this? Anyone else has this problem too? Not even applying the textures manually will help, it insists on using the texture map for transparency.
Every
organisation rests upon a mountain of secrets ~ Julian
Assange
I have P7 with the SP1 patch, and whenever I render with Firefly the result is a blank. Just the background color shows. Weird, huh? Any ideas?
Running a Pentium 4 CPU 2.66 GHz, 1.25 GB RAM, Windows XP SP2, NVIDIA GeForce 6200 256 megs DDR.
Thanks in advance,
Guy
