Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2025 Jan 21 7:59 pm)
Hi melancon,
I'll pass your suggestion to the admins.
Cheers!
Barb
My
crafts - My Freebies -
My Store - Delightful Arts
I have noticed that fractals do have larger files than other types of 2D and 3D softwares generate. I can very frequently have a 200 x 150 thumbnail that is 93 k or more and have to bring it down to about 45% compression to make it 15 or less. That results in the type of horrible thumbnail that I had to post yesterday. I'm not sure why fractals do that unless it is simply that there is so much more information in the image with all the edges and color changes that come from the recursive formulas. Has anyone found a way to cure this problem?
~Viv
Fractals will always amaze me!
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2678201
See that thread in the Poser forum. That should help be able to keep your images at a larger dimension while still being able to compress it to fit the file size limits."It is good to see ourselves as
say." - Ghandi
Well I thank one and all for the help and advice. I solved the problem very easily. I went here
www.irfanview.net and downloaded the latest version of an old favorite freeware program. It lets you resize and adjust the quality of an image. Works like a charm.
Thanks again,
Michael
A suggestion: when using jpeg keep both size multiple of 8. Jpeg compression works on 8x8 blocks, so if you have 170x170, it is about the same of 176x176. So if you want little file it's better 168x168.
Eventually yuo can crop some pixels if you want the same aspect ratio. I use imagemagick to resize my images/crop, it is a commandline tool. Irfanview has a small bug when resizing very big images (about 6-7000Pixel in one side), it creates a small black line in the right size of the image.
Also the contrast adjuster of IView is not so good (i had to write my own one).
I also think that 512KB limits is very low, but "a caval donato non si guarda in bocca" (Italian popular phrase about free stuff), so i cannot complain about something free.
I don't use strange effects, multilayer, texture, etc.... my fractal are only about details and math and some of them lose ALL their beauty when resized to 500K.
I dont what the fuss is all about, since Rendorosity automatically makes a thumb nail for you as long as your image meets the file size restriction of 500k... and since discovering this ive saved time not having to ever create another thumbnail in photoshop and also space on my h/d.....just upload your image & let Rendo do the rest :)
psion005
DROP ACID NOT BOMBS!
Well once again I was not able to post an image here as I could not get it down to 15K to meet
the maximum limit for the thumbnail. I also would have had to reduce the image to 800 X 600
instead of 1024 X 768. With the higher resolutions of modern monitors I think this should be
addressed. Oh well nuff said.
