Fri, Jan 24, 5:43 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 4:20 pm)
Subject: How do I get rid of un needed dials in a figure?
pokeydots ( ) posted Tue, 06 March 2007 at 10:05 PM · edited Fri, 24 January 2025 at 12:29 PM
I have to remove some un needed dials in something I made, but I'm not sure how to do this. I don't want to hide them I want to remove them. Does anyone know how?  Thanks ;o)
Poser 9 SR3  and 8 sr3
Processor Type:  AMD Phenom II 830 Quad-Core
Hard Drive Size:  1TB
Processor - Clock Speed:  2.8 GHz
Operating System:  Windows 7 Home Premium 64-bit
Graphics Type:  ATI Radeon HD 4200
System Ram:  8GB
svdl ( ) posted Tue, 06 March 2007 at 10:14 PM
You can use a cr2 editor (those will edit other poser files too, btw) to strip out targetGeom (morph) and valueParm (morph controllers, usually located in the BODY bodypart).
A good one is CR2Builder by kim99. Don't know the link off the top of my head, it was 3minutesPoser or something like that. Google will find it.
My gallery   My freestuff
Acadia ( ) posted Tue, 06 March 2007 at 10:17 PM · edited Tue, 06 March 2007 at 10:18 PM
I've asked this too but never really got a time saving answer.  The one I remember was to go and delete each single morph individually.  I don't have the time nor patience to spend 3 hours deleting several dozen individual morphs so I've just left them.
pokeydots ( ) posted Tue, 06 March 2007 at 10:17 PM
I have cr2 editor, but I'm not sure what I need to remove :(
System Ram:  8GB
Acadia ( ) posted Tue, 06 March 2007 at 10:20 PM · edited Tue, 06 March 2007 at 10:22 PM
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=2841023
Maybe try that thread. It didn't help me because it was way over my head and I didn't understand it, but it might help you.
Here is the thread where I asked about it.
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2663088
svdl ( ) posted Tue, 06 March 2007 at 10:24 PM
Hmm. I know what I have to do when I do it by hand - maybe I should think about writing a Python script that does the same, but then fully automated.... Ach, so much to do, so little time...
jerr3d ( ) posted Tue, 06 March 2007 at 10:29 PM
In Poser 7 (not sure if this works in 6 or 5) if the dials are morphs, just pop up the arrow to the right of the morph dial an select "delete morph" if it is a transform dial though, this won't work.
Miss Nancy ( ) posted Tue, 06 March 2007 at 10:42 PM
it appears that steve wrote the script to delete morphs, but his site wasn't responding just now (0440 gmt, mar 07).
pokeydots ( ) posted Tue, 06 March 2007 at 11:02 PM
Silly Me!  I have PhilC's tool box and there is a tool in there to do it!  Problem solved!  Thanks everyone for you help! I appreciate it very much ;o)
System Ram:  8GB
dphoadley ( ) posted Wed, 07 March 2007 at 4:40 AM
Why not just (Poser 5-7) right click the dials you don't want, and then delete the morph, and then resave the figure?  Or is there something that I've missed here (very probable)?
DPH
pokeydots ( ) posted Wed, 07 March 2007 at 4:59 AM
These were morphs that for some reason I couldn't delete in poser, don't know why but right clicking didn't have a delete option.
System Ram:  8GB
Angelouscuitry ( ) posted Wed, 07 March 2007 at 6:30 PM
SVDL - Hi!
Pokeydots - SVDL here(...?) has a script called RemoveMorphs.py, that will delete any morphs set to 0; for your future reference.  It's really easy to run, and takes hundreds of MB off some V3.PZ3s.
Acadia - You never got it, I thought I sent you an IM telling you to ask me if you were'nt clear?
momodot ( ) posted Wed, 07 March 2007 at 9:56 PM
I have an idea for using svdl's remove script that I have not tried out: a MOR pose that would set all the dials I want to keep (expressions mainly) for a certain figure (V3, V2, etc.) at a low value like 0.001. The pose should not effect any spawn morphs right? Then I could run the script and ctrl-e my dials back to true zero.
pokeydots ( ) posted Wed, 07 March 2007 at 9:57 PM
Thanks, I used Phils poser tool box and it worked ;o)
System Ram:  8GB
Angelouscuitry ( ) posted Wed, 07 March 2007 at 11:00 PM
Momdot - SVDL's script comes with a set of .exc files, for certain characters.  These file keep expression morphs from being deleted.  I need to hack that file, by deleting the contents, to deelte the expression morphs; and hence shrink my figure as much as possible.
I think the script will work on any morph, be it spawned or not.
momodot ( ) posted Wed, 07 March 2007 at 11:38 PM
I'll check... maybe I have an early version without the .exc it is just a .py without anything attached.
