Sat, Jan 25, 10:57 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Carrara Free Stuff here.
Subject: Grey ground plane (maybe) showing through prop floor...
ghelmer ( ) posted Sun, 11 March 2007 at 11:54 PM · edited Sat, 25 January 2025 at 10:57 AM
Occasionally when importing a P6 scene (room prop and character) into Carrara 5.1 Pro I get what appears to be the Carrara ground plane over parts of the poser prop floor/ground area!!!  I've tried raising the entire poser props & characters above the carrara ground plane, or angling the poser props and still the gray (sometimes white) area still pokes through!!!  I'd post pics but I never saved any so I know I'm not providing much to go on to diagnose!!  SORRY!!
Any ideas would be totally appreciated!!
Thanks!
Gerard
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
ominousplay ( ) posted Mon, 12 March 2007 at 1:35 AM
It might be the Poser ground plane. Poser 6 has a ground plane, and if you bring in the Poser file, the ground will come with.
Never Give Up!
ghelmer ( ) posted Mon, 12 March 2007 at 1:53 AM
I always delete the Poser ground plane once in Carrara...  forgot to mention that!!  But thanks!!  I just wish I could get this figured out!!!
The GR00VY GH0ULIE!
danamo ( ) posted Mon, 12 March 2007 at 1:57 AM
I haven't imported a Poser scene into Carrara (yet), but one thing that occurs to me to try is to go to the INSTANCES tab, select SCENE, and up to the EFFECTS tab, then check the Atmosphere setting. If it is the Realistic Sky setting make sure the ENABLE GROUND toggle box is unchecked. HTH, Dan
danamo ( ) posted Mon, 12 March 2007 at 1:59 AM
The Realistic Sky comes with a Ground Plane as the default setting.
ghelmer ( ) posted Mon, 12 March 2007 at 3:52 AM
Thanks danamo!!  But alas it did not solve the problem...  I unchecked enable ground, deleted poser ground did everything listed above and still have the weird patch...  rendering again, different render settings and lights and am hoping maybe that'll do it.....
Gerard
The GR00VY GH0ULIE!
MarkBremmer ( ) posted Mon, 12 March 2007 at 5:37 AM
Can you post a screen shot of the scene? It would help to see what you are talking about. ;) Here is a possible fix though: In some camera positions, sometimes Carrara has issues with things at z=0. Check "Full Raytracing" in the Render Room and see if that fixes the problem. Mark
ghelmer ( ) posted Mon, 12 March 2007 at 5:43 PM
Thanks Mark!!  I'll give that a try when I get home from work!!!  Also I'll post a pic of it!!
Thanks all!!
Gerard
The GR00VY GH0ULIE!
jt411 ( ) posted Mon, 12 March 2007 at 11:09 PM
First, make sure "Full Raytracing" is checked in your render settings.
Secondly, if you're using a basic sky, lower the ground altitude by an inch or two.
ghelmer ( ) posted Tue, 13 March 2007 at 12:16 AM · edited Tue, 13 March 2007 at 12:18 AM
Well here's what I'm getting...  Am currently re-rendering with Full Raytracing ticked...  will post results!!
Sorry for the nudity!!  Heh!
The GR00VY GH0ULIE!
ghelmer ( ) posted Tue, 13 March 2007 at 12:34 AM
YAY!!
Looks like the Full Raytracing did the trick!!
Thanks to all of you who replied!!!  I totally appreciate it!!!
Time to render at full size and with anti aliasing on again!!
Thanks again!!
Gerard
The GR00VY GH0ULIE!
ghelmer ( ) posted Tue, 13 March 2007 at 3:15 AM
Attached Link: http://www.renderosity.com/mod/gallery/index.php?image_id=1401413
Hmmm...  Turned up the light intensity a smidgen, re-rendered...  then did way too much postwork and I think I ruined it...  both postworked and non postworked just didn't turn out like I planned!!
BUT, I really want to thank you guys for the help and advice!!!
Thanks!!!
Gerard
The GR00VY GH0ULIE!
